surging and dies when around 1/4 tank of gas?
Need some help..truck runs great until i get around 1/4 tank of gas! took it to the dealer which replaced the fuel pump,(28psi), #1 & #2 injectors, and filters Ran fine for a couple miles and started back up again, (tank was around 1/4 tank).
Truck will start surging with little power and if i don't keep my foot on brake and gas it will die. Any ideas |
What kind of fuel pressure do you have now at idle and at WOT did they install a new fuel reg. spring so does it run OK on the full side.
2 stroker
He said fuel pressure was good, i'm not sure if he installed a new regulator?
sounds like maybe a problem with the pickup in the tank or maybe your sending unit is off and you are actually lower than 1/4 tank? How much fuel does it take to get from 1/4 tank to full?
I will check at next fill up but i believe when i filled with around 18-20 gallons Sunday, right when it started acting funny |
FICM may be bad
ive seen several that the fuel sender in the tank were off some , and ive seen some with some pick up issues , your probably looking at going into the tank and see
Is that normal to start out of know where? Is it difficult to do?
I have read a few threads on here about the fuel pickup cracking and causing this issue.
yea it can ,, as long as the tank isnt full ,its not that bad
