Replaced carrier bearing and rear pinion seal now showing P0500? - Ford Powerstroke Diesel Forum
Old 12-12-2011, 04:06 AM
This past weekend i replaced my drive shaft carrier bearing, rear pinion seal, and replaced fluid in rear diff. Everthing went well i thought, ran trouble codes check on my CTS and am now showing a P0500 for a VSS? Fault. Just curious what you guys think i should Do?
Thanks
Old 12-12-2011, 04:31 AM
Maybe you accidentally knocked it loose? If it's like mine, it's on the rear diff?
