Sagging front spring? Is there a fix?
Ok guys i cant take it anymore. My truck leans toward the drivers side and i cant stand it. I swapped out known good front springs from a 04- 350 drw and the same thing. The drw didnt lean either.
Is there something i am missing? What else can be replaced? Is it the spring loaded shackle bracket? Any and all info would be great guys, thanks Mike |
The fuel tank is on the drivers side. 38 gallons x ~8lb/gallon is 304lbs so that isn't helping any. Maybe check play in the front joints?
You could get like a half inch block and put on driver side or buy a brand new spring pack that should level you out
Timbren Load Springs
Whole front end was rebuilt 2 years ago and nothing changed. |
Air bags would probably be the way i would go tho. |
When you swapped spring did you get them on the right sides?
Left and right side actually. But I know what you mean and yes, left to left and right to right. Not that it should matter. Like I said the truck that they came out of didn't lean at all.
my obs does that. never figured out why. looked for suspension issues, couldnt find any.....
