Bad Thermostat?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-10-2011, 02:50 PM Thread Starter
JimboJames's Avatar
Bad Thermostat??
Ok so today it was 10 degrees here in Wisconsin and I not could get my truck to go above the 140 degrees on EOT and the coolant read 135. So this whole time I was not getting much heat at all if any. I was going to change out the thermostat tomorrow and see if that helps. Any thoughts?
05 F-350 lariat 4x4 crew cab SB
4" straight pipe
SCT innovative's extreme street
edge insight
leveling kit 35" Nitto terra grapplers
ARPs & EGR Delete
Warren Diesel Stock+ injectors
JimboJames is offline
post #2 of 10 Old 12-10-2011, 03:04 PM
pizza pig's Avatar
replace the thermostat
pizza pig is offline
post #3 of 10 Old 12-10-2011, 04:52 PM
Only go back with a Ford t/stat because when they fail, they fail open plus i would get a new o-ring 3C3Z-8255-AA Thermostat Housing O-ring
3C3Z-8575-AA Thermostat with housing
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 10 Old 12-10-2011, 04:57 PM
Powerstroke Techie
forddieseldoctor's Avatar
Go motorcraft for a new thermostat. Comes with a new housing.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #5 of 10 Old 12-10-2011, 09:38 PM
F250SixOH's Avatar
O-ring is included with that kit by the way
F250SixOH is offline
post #6 of 10 Old 12-10-2011, 09:47 PM
rfishoutofwater's Avatar
i just replaced mine over the thanksgiving holiday and you might as well replace the temp sensor too. i paid like 65 for both the thermostat and the sensor both from ford. only use the ford thermostat.
Sinister EGR Delete, Diesel Site Coolant Filter, 5" diamond Eye Turbo Back exhaust, MBRP BLack Tip, SCT Livewire, Glow shift gauges, Go Rhino Grille Guard, Ride Right rear airbags....
rfishoutofwater is offline
post #7 of 10 Old 12-23-2011, 01:51 PM
i had the same problem but mine would not go over 160 put a new tstat in same problem both ect and eot are the same will not go over 166 any ideas
pizza1424 is offline
post #8 of 10 Old 12-23-2011, 06:39 PM
Powerstroke Techie
How are you monitoring your ect and eot?
Meet Double Aught
2000 F250
post #9 of 10 Old 12-24-2011, 05:34 AM
edge cs and the factory gauge reads low and i put a mech gauge in the degas bottle all read no higher then 170 (this all happened after i washed my truck) figureing i got some thing wet i let it dry out for a day same
post #10 of 10 Old 12-24-2011, 05:42 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
So....what did you figure out OP?
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
