SORRY GUYS-Another P2290 code question
I just got back from driving my truck hard on the interstate for about 100 miles, did not pull anything just wanted to run it through its paces (and do a little Christmas shopping). This is the first time I have really been able to run the truck since I had some major work done:
Replaced HPOP Repaired FICM Replaced #8 injector New Alternator I have cleared the P2290 code but it comes back. Just now I noticed when I shut the truck of I get a short but loud "fsssssst" sound for a split second. Any ideas? Many thanks. |
Check your ICP sensor for oil leaking, or oil soaked wire harness and plug, along with wire chaffed/damage. Also check your oil dip stick, not enough oil in the pan can also cause the code.
Will head and check now. |
No oil observed leaking from the ICP sensor Examination of wiring harnesses did not show any unusual chaffing Oil level full Removed ICP sensor connector and cleaned. Will check out tomorrow on a short trip to see if this clears up. Again my thanks. |
I'm not calling you out but where are you checking the ICP? On your truck it should be on the back of the motor just behind the turbo. Took me about 3 hours to replace mine. If your getting that code I'm 99% sure your ICP is bad. Do a search on ebay. They are about $60 on there.
On another note, even our founding fathers said, ".....we should not fear our government, our government should fear us." Last edited by WarChild; 12-12-2011 at 04:13 AM. |
About 2 weeks ago, my alternator went out and I realized I was running on batteries until they died and left me beside the road. Not sure if this created some of my problem or not.
AMEN Brother!! |
I use to have my IPR shield off also, until this happened!! Heat from the turbo and y-pipe makes the wire insulation brittle.
wow, that looks nasty. But mine has been off for a while now and doesnt look like that. maybe yours was touching something? Idk.
| Tags |
| hpop, oil leak, p2290 |
