Tuning throwing codes? - Ford Powerstroke Diesel Forum
Old 12-09-2011, 12:58 PM
First off I have Vivians tunes and I'm going to call her today to get an answer from the source, but I wanted to see if any one else has the same or similar issues.
When my truck is stock I get no codes or smoke out of the tailpipe. But when I load my tunes I get a FICM incompatibility code and a MAP/BARO correlation code. It also blows a fair amount of blue smoke (smells like diesel not oil).
Are these issues that she can fix in the tune writing?
Old 12-09-2011, 02:45 PM
Is that a U0306? I am getting that when I connect my CTS, reflased my FICM yesterday and that made no difference, Edge had no answer/solution. Three year with a Hypertech and no such code. This is my 2nd CTS in 2 weeks and both threw this code immediatly.
Old 12-09-2011, 02:52 PM
That sounds about right.. I'm not so worried about that one, I spoke to her about once before, and was told is basically from the tune being based off a different strategy than what the FICM expects to see. But it shouldn't cause any problems.
The MAP/BARO code is the one that has me curious since fuel mapping and VGT cycle takes those readings into consideration.
Old 12-09-2011, 03:08 PM
Check the rubber line from the map sensor, especially if it has been "t" into for an accessory, I ran into this once way back, a new tune makes more boost and it lets go
Old 12-09-2011, 03:20 PM
I've checked it, and ran a Allen wrench through the manifold nipple and alls well.
I only get that code when it's tuned, if I put it back to stock the code disappears. Which is why I'm wondering if it's something written into the tune that's making the code pop up
Old 12-10-2011, 12:12 PM
I get the cam shift poisition sensor error when I have my SF3 on performance
Old 12-10-2011, 12:33 PM
It's weird that the code only pop up while the truck is tuned.. Hopefully Vivian can sort it out when I talk to her
Old 12-10-2011, 12:38 PM
If she sorts it out for you let me know. I am getting the same identical codes and only on looney as well.
Old 12-10-2011, 12:40 PM
What year truck do you have? I'm wondering if it's a 03-04 issue.. but, it's worth a thought
Edit: sorry, just saw you have a 04.. Haha. Stupid autoguide iPhone app..
Old 12-10-2011, 12:43 PM
Mines an 04. We are the red head step children with the 03-04. Can I pm you her response?
