$10,000 to spend on what?
Hi fella's. I'm looking to get some security/performance into my 6.0
I don't want to do it bit by piece, I'd rather get it in one bite. Here's where it's at: -2006 with ~80,000 miles on the clock -Just recently began throwing a code, diagnosed as turbo coking. No noticeable drive issues as a result yet. -Every single thing is stock, mechanically. -Been a dependable truck, starts good even in -40 Saskatchewan winter. -Currently getting ~11mpg -Silicone boots on intake tube are saturated and permeable due to oil so they are a must change. -Truck is lifted a bit and decked out to my liking so I need no cosmetics. -Well maintained always ran a good synth oil and changed every 6000km, fuel filters every 2nd oil change. In order of importance I'm gunning for the following: -Reliability -Fuel Mileage -More power -Tougher sounding I just bought my wife some granite counters so I have a small window of opportunity to invest around $10,000 into my own gear, without the risk of sleeping by myself. ![]() What would you suggest, and in what order of importance if you were looking to accomplish these goals? Tentatively I've come up with the following list based on research of this site: -Replace turbocharger (peace of mind more than anything, but if I'm having it pulled apart anyhow I just as well put a new possibly slightly larger unit in) -If new turbo is larger then larger injectors and fuel system to support it. -Replace silicone boost boots (current boots permeating oil from intake tube) -Replace fuel pressure regulator spring with Motorcraft Part # 3C3Z-9T517-AG -Flush coolant system with distilled water 3-4 times, then run "Restore" for 1-3hrs flush with distilled and "Restore Plus" 1-3 hrs, flush with distilled 3-4 more times. -Replace oil cooler system -Replace EGR with a delete kit -Install Edge CTS for data, SCT X3 for tuning. -4-5" exhaust -Stock air cleaner -ARP head studs -OEM head gaskets These are just ideas I have from reading the site here. I'm open to any and all ideas from you, just keeping in mind that my number one priority is dependability/longevity. Power is fine only as a side effect of increased fuel mileage. Thanks for your input, looking forward to the build and hopefully patronizing this sites sponsors. Kevin. Last edited by Evilsports; 12-09-2011 at 08:48 AM. |
Just to be clear, I won't sacrifice dependability for anything, I won't sacrifice fuel mileage for power or sound, and I won't sacrifice power for sound.
You've got a damn good idea going there..
Although I will suggest, look into bullet proof diesel's oil cooler. It relocates it as a front mount And moves your filter off the top of the motor... Much better... Also look into a coolant filtration kit.. Even with the flushes, you may Have Junk left in there... If you don't want to sacrifice mileage, idk about going with bigger injectors and a bigger turbo... I'm not positive but I think you will loose some there... Being where you are I'm Assuming y'all are on winter fuel year round? Idk how that will come into play for bigger injectors. Sent from my Autoguide iPhone app |
Excellent list there. Too add to it if you are going with a larger injector and turbo you will need a fuel system.
I agree with everything said so far.
I just want to add to the list a CCV mod. This will prevent your boots from getting saturated again. You can DIY or buy a kit for it. A quick search on here will turn up a lot on it. Oh, and go ahead and go with the 5" exhaust. Make sure you get the larger down pipe to go with it though. |
Maybe bigger intercooler, the banks technicooler kit looks like the best bang for your buck there. If you decide to go with bigger turbo/injectors I would get an airdog or FASS fuel system while you are at it.
Thanks for the advise on the bigger turbo/injectors, I hadn't thought of that. I think I'd still like to get a new turbo, possible OEM..? I can always split the old one and polish it up for a spare/resale. I'm kinda looking for as little down time as possible. Last edited by Evilsports; 12-09-2011 at 10:57 AM. |
I'm more leaning towards a new OEM style turbo. I'd be willing to either take a bit of a hit and resell the old one once it's refurbished, or even sitting on it for a back up. |
you could look at the powermax turbo which is a slight upgrade from stock and you dont need aftermarket injectors or fuel system. bolts right in no modifications.
i have been trying to find a way to get better gas mileage from the beginning and its impossible. i get 11.92 mpg no matter how i drive but basically the only way to change your mpg is to change your right foot. plus your lift and bigger wheels arent helping your situation. you got a good list going there, doing all that with low miles will benefit big time in the long run. *****edit: 2 6.0's and never blown a boot but maybe some trucks are different Last edited by travisH3; 12-09-2011 at 11:05 AM. |
