EGT probe at the turbo? - Ford Powerstroke Diesel Forum
Old 12-09-2011, 08:16 AM
This has been bugging me for a while now.
Has anyone put the egt probe right at or in the exhaust inlet of the turbo?
Just wondering if this area would be the best for temp readings? I know, the manifold is the gospel, but could this area be better?
Old 12-09-2011, 08:32 AM
Almostdunfukinwidit
Wouldnt read any different than at the manifold. And would be harder to get to.
Old 12-09-2011, 08:37 AM
Well ok, then what about right at where the DP hooks up? I would assume that area would stay cooler due to having the turbine housing volume diluting the heat load.
Old 12-09-2011, 08:50 AM
I'd think that you'd want to keep the EGT probe on the pressured side of the turbo.
Pressure=Heat
Old 12-09-2011, 08:52 AM
Glow Plugs Only
At the moment mines in the downpipe aft the turbo. I'm moving it to the drivers side manifold for more accurate readings when I tear everything down to do the ARP studs and gaskets. Done allot of research, it's also where all the gauge manufacturers suggest as well.
Old 12-09-2011, 09:30 AM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
Mine is to. I just keep it less then 800* for extended periods and 1000* if it's a quick hammer down/race. Had no issues thus far
Old 12-09-2011, 11:06 AM
ihad it at downpipe before. but reading was really low. talket whit matt @gearhead he said put it in mainfold now i see whole different readings.
Old 12-09-2011, 11:17 AM
Feedback Score: 3 reviews
I use to have mine in the down pipe, 4" after the turbo. My EGT's would only reach 1100* @ WOT with a race tune post turbo. Now it's in the manifold and at WOT with a race tune I can get 1500+ EGT.
Old 12-09-2011, 05:12 PM
dee004 sent me this link. He and I had the same discussion. I was ready to mount my EGT sensor in my down pipe til I read this article.
Ford Diesel Power Powerstroke Performance
I am now going to mount it in the drivers side exhaust manifold.
Old 12-09-2011, 06:28 PM
I understand about downstream of the turbine wheel getting cooler readings. the volume of the DP is greater that the up-pipes or manifolds which would make for a greater cooling effect. I was talking about right at the turbine wheel in either spot(inlet or outlet). I would feel that either spot would give the best temp reading at the turbine. I feel the manifold gives a better reading at the exhaust valves, ports, and pistons.
I have a probe in both headers and the passenger side reads around 50* hotter due the longer path compared to the drivers side. Not to mention the bend at the exhaust inlet.
