high idle mod for my 05
2005--- i have read alot on the forum for high idle, but they give you a few different wires to pick from.. i just need to know what two wires ( colors ) that i need to hook together to make it idle at 1200 rpms i just want it for the cold winters so if someone could just let me know what two wires i need that would be great thanks im pretty sure there is one by the ebrake and other by the port where you would plug your sct in to
sorry if you guys are tired of hearing this |
I read on a thread somewhere here where someone did this without needing a switch i thought? I can't find the thread now.
I want it to just default to high idle if the emergency brake is pressed and the truck is in park. |
is there anyway for me to use my up fitter switch without having to apply the e brake??? On my 03 I had it to a toggle on the dash and did not need the e brake to be engaged for it to work. On my 05 I used the upfitter switch but I have to engage the e brake and that is not a big deal but it's less convenient...
anyone got a link for an 04? or is it any different then an 05, would really like to do this for winter....
http://dan.prxy.org/Truck/Other/High...mod.html#NoMan |
Get a custom chip with a high idle setting, you can put it in high idle under water with your trucks blinker fluid bone dry if youd like!
