EOT vs ECT on scanguage - Ford Powerstroke Diesel Forum
Old 12-07-2011, 03:23 PM
I just hooked up my scanguage, loaded all the important xguages onto it and went for a hour drive down the highway at 65-70, oil temp never exceeded 150 F and coolant was around 188 the entire time, 37* outside temp. I double and triple checked the programming in the xguage. Is this about normal for the oil temps? all the threads Ive looked thru everyones at or above the 15* delta so i dont know if this is the norm or i did something wrong. I got the Xguage values right off the scanguage site so I'd assume their vales are correct, If the oil temp is correct I'm a happy camper and have nothing to worry about. Just wanted to run it by the .org crew and see what everyones thoughts are.
Old 12-07-2011, 03:31 PM
Something is up. An hour of driving should have your EOT at or a little higher than ECT.
Let it sit over night with a cold soak, and compare the temps. They should read nearly the same. If they are not, try entering this 00090005FFD8 in the MTH for your EOT. And recheck the 2 temps. See if that helps.
i have the stock cooler and run edge cts and it comes up 192 ECT and 190-192 EOT which is on the mark, your EOT seems low i think, unless maybe you have a Bulletproof Oil cooler and it doesnt have a t stat or so. seems off tho maybe someone who has a scanguage can chime in
Old 12-07-2011, 03:39 PM
Send a message via AIM to dieselmatt
I agree with 06SuperDuty, it is low unless you are running a different oil cooler and failed to inform us of this. My temps are usually 180 ECT and 188 EOT.
Old 12-07-2011, 03:44 PM
truck is stock, had head gaskets, egr, egr cooler, oil cooler done at 85k, 99k on the truck now, Ill give the new code a shot and see what happens
Old 12-07-2011, 05:46 PM
not sure what I did wrong but I went out and reloaded everything now its reading 183 EOT and 188 ECT so it looks like im in the norm. thanks for the help guys
Old 12-07-2011, 07:04 PM
NO you are not normal something is wrong EOT is never cooler than the ECT a stock Ford t/stat starts to open at 192.2* and is fully open at 219.2* so you have a t/stat that is stuck open better than closed or you gauges are screwed up. My run ECT 192-194* EOT 200* when pulling my 5er add 10* to each and the highest i have see it ECT 218* EOT 228* pulling a 6% grade 6 miles long 90* outside and the fan sounds like a jet plane so you are running to cold if your gauges are right, even in colder weather you have to get to 192*+ before the t/stat open or it is stuck open.
2 stroker
Old 12-07-2011, 07:46 PM
Your T-stat is bad by the way.
Old 12-07-2011, 09:01 PM
Its brand new
I actually thought the same thing so I took it back and traded it for another one, same thing. It is just a different brand, not OEM, so that explains the difference on my end.
Old 12-07-2011, 10:17 PM
A truck that runs on the cold side will use more fuel because the computer is adjusting for it better to run warmer than cooler but not hot.
2 stroker
