Bulletproofing list - Ford Powerstroke Diesel Forum
Old 12-07-2011, 04:19 AM
Glow Plugs Only
Bulletproofing list
Heres a list of what I have so far if there is anything I'm missing please let me know. I'm thinking I may need a complete set of injector o-rings and copper gaskets as well.
Bulletpfoof Oil Cooler Kit with cold air package
OEM Head Gaskets
ARP Studs
Updated STC fitting
Updaeed IPR screen and o-rings.
Intake Gasket Kit
Thermostat o-ring
Turbo gaskets and o-rings
EGR o-rings
Blue Spring Fuel Kit
Upgraded Turbo Drain Tube
UpdatedTurbo Oil Feed Line
Exhaust manifold gaskets
6.4 Banjo Bolts and washers
Fleetguard Restore Plus
Zerex ELC CAT EC-1
EGR, Intake, Gauges & Kitty taken care of previously
Old 12-07-2011, 05:34 AM
Slacker
Feedback Score: 4 reviews
Wow, seems like a GREAT list. There isn't an updated IPR screen, but if you are talking about having a spare to replace yours, then I would agree having one on hand in the event yours is torn would be a good thing. You probably don't need the exhaust manifold gaskets. I don't know why you would remove your exhaust manifolds for any of the procedures unless you have a leak. If that's the case, just double check your manifold bolts to ensure they aren't backing out on you.
Old 12-07-2011, 05:49 AM
I would add regular restore to that as well. help get the goo out. Other than that, looks fine.
Old 12-07-2011, 05:52 AM
The 6.0L from the factory did not have exhaust manifold gaskets, no need for them. Also the STC fitting upgrade will come with a new IPR screen and o rings. Make sure that you have the cylinder heads machined and pressure tested. Check out this thread-- How to Machine the 6.0
Old 12-07-2011, 06:38 AM
Glow Plugs Only
A Ford Tech in town told me I needed exhaust gaskets hmmm. Going to be drilling and tapping the drivers side for the EGT thermocouple. At the moment it's aft the turbo in the downpipe. Rather have in the exhaust manifold for a more accurate reading. Got the IPR screen just in case. Will get the restore as well, used VC-9 last flush from the Ford bandits. The write up from Gearhead on the milling of the heads is absolutely awesome, thanks a2elvis for that. As the younger crowd would say that's sick...
Old 12-07-2011, 07:03 AM
Glow Plugs Only
How important is it to replace the Standpipes, Dummy Plugs? Should I consider this upgrade as well and why?
Old 12-07-2011, 07:17 AM
NOT a Democrat
You forgot Kevlar
Old 12-07-2011, 07:27 AM
Glow Plugs Only
I have kevlar ear muffs for when the Boss's naggring at me for spending too much time in the garage with my baby LOL.
Old 12-07-2011, 09:49 AM
Slacker
Definitely do them while you have it apart. The older style (prior to mid-06 or so) were more prone to leaking. If your truck is later than that, you already have the newer style.
I need to pick up a set of those!
Old 12-07-2011, 11:22 AM
Glow Plugs Only
Standpipes and dummy plugs added to the list! Anyone have a part # for them by any chance? Will surf on over to Tousley.
