New to forum: Buying a 06' F250 PSD
Hey guys, new to the forum and to diesel ownership. Was curious if there are any special maintenance procedures that need to be undertaken to keep the 6.0 in good shape. Ive noticed EGR replacements, Oil cooler replacements and head gasket replacement with ARP studs are a few of the mods to make it "bullet proof". I was looking more for general house keeping stuff that a newbie might over look. Also, are there any general concerns that I should look out for with the f250 in 06'? Thanks for any help you all might be able to offer.
Brian |
Let me preface by saying that I am SUPER anal about maintenance on my vehicles...
![]() First thing I would do is all fluid and filter maintenance (i.e. oil, oil filter, fuel filters, air filter). You'll be doing this every 5k (10k for the fuel filters, air filter as needed) anyways, so might as well get a good start now. Switch the oil to a good 5W-40 synthetic. It makes for easier starts and longer engine life. Figure $150-200 if you do it yourself. I would also change the coolant to an ELC coolant (Fleetrite or similar) to stop any buildup that has occurred/is occurring in the oil cooler. Figure another $250 or so at a reputable shop. Most places won't take old coolant, so use a shop unless you have somewhere to dispose of it. Assuming the truck is 4x4 and auto transmission, the next thing would be to check and replace all driveline fluids (tranny flush, fr/rr differentials) if the truck has over 60k on the clock unless you have proof that these fluids were changed in the last 30k miles. If the truck doesn't start right up after the glow plug light goes off, I would replace both batteries, as the engine needs a ton of compression, strong oil pressure, and a crank speed of 500 rpms to start. These items will take the "unknown" to known-good. FYI - there isn't anything "special" or unique about this maintenance...just MUCH larger in scope and cost that a gasser. The PSD holds 14-15 quarts of oil (that's almost 4 gallons) instead of 5 quarts, and there are two fuel filters (one in the engine bay and one on the frame rail just under the driver's door). It can easily be done in your driveway in less than an hour with basic tools. [RANT] Oh yeah, PLEASE clean the engine bay. Nothing drives me crazier than a dirty engine bay, especially when you are performing maintenance. A clean engine bay also makes it easier to read fluid levels, notice leaks, etc. Plus it looks better. [/RANT] From here, it gets a little more sophisticated and depends upon your comfort level and checkbook. However, I strongly recommend that your very next purchase be an Edge Insight monitor. This will allow you to monitor oil temp vs coolant temp variance (will tell you if the oil cooler is clogged, which could cause the EGR to leak coolant into the intake) and FICM voltage to determine if the FICM is in good shape (48V or higher). Other items can be checked/monitored for indications of problems, but I'll let the more knowledgeable folks comment on those. Sorry for the long read...hope this information helps!!! Last edited by texas_psd; 12-07-2011 at 05:49 AM. |
Correction made.
Thanks for the information. Signed papers today and should have it by tomorrow. I'll post pics asap. A little apprehensive because this is my first diesel, but excited to get on that learning curve and own a great truck.
@ Texas_psd: Do you like your Pioneer Nav unit? I was looking to put a nav unit in mine and had found a place up in Canada selling Stock replacement units with more options. eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices Was curious if you had any recommendations. Also, I was looking to fit a center console from either an expedition or navigator. Has anyone attempted this mod and had it turn out OEM looking? Thanks |
Welcome aboard! I look forward to seeing the pics of your new ride.
Sent from my Autoguide iPad app |
Congrats on the new truck! As far as the console, if your truck has the bench seat, your best bet is to pull the center section out and replace it with an 08+ console. That is a much better fit than an Expedition or Navigator console and will only require picking up some correct brackets to make it fit.
Here are some pics
