What Alternator To Accomodate Acc.
My alternator seems to be struggeling now with keeping the voltage up. At idle the voltage hangs out at about 13.3 - 12.9. I just ordered a set of long range 130watt lights and a set of driving lights at 100watts. Also the truck is fully loaded with seat heaters and all. I have no aftermarket stereo but I do charge a variety of accessories and tow, so trailer lights. Can I just go with the 140amp ford alternator or should I jump up to the 185 or 190 DCpower alternator.
To answer your question correctly, you would have to know what your system amp draw is. Do you have access to a DC clamp meter? Having said that I don’t think you could go wrong with a larger unit.
i like this one for a small upgrade: Stealth Automotive Inc - DC Power Engineering Alternators :: 190 Amp OEM High Output Alternator for 2004 -2007 Ford F-250 Super Duty 6.0L V8 Powerstroke Diesel
they go up way higher in AMP but they are more expensive as well... |
No I dont have access to a DC clamp meter. I would like to just get the OEM 140 amp but I don't want to buy that and realize its not enough and that its running at its max the whole time.
i had the 190 OEM DC power alt on my excursion and i very much liked it... i also had in dash touchscreen, flip down tv, amps, subwoofers, along with having many things plugged in and it never gave me a problem.....
i have the 190 that Raul is talking about.... I'm very happy with it
Just put in an order for the 185 from DC Power. Didnt see the need to pay the extra money for the 190.
What Timvo said. I went with the 190 (actually should be delivered today) but that was just me...The 185 is several dollars cheaper and I am not sure the extra 5 amps is worth the extra money. If the extra 5 amps will make a big difference, you may want to go with a 225 amp, BUT they are really expensive.
