Orange coolant? - Ford Powerstroke Diesel Forum
Old 12-06-2011, 08:06 AM
Orange coolant?
I have a 2005 F250 FX4 that I purchased used about seven months ago. The coolant that is in the vehicle is a reddish orange color. Does anyone know if this is an ELC or if it's something else? I will post a picture tonight. Thanks in advance.
Old 12-06-2011, 11:40 AM
ELC coolant is RED in cooler Ford Gold junk Is a Gold Green in cooler need to get some gauges and a coolant filter ASAP to see the health of your motor.
2 stroker
Old 12-06-2011, 12:04 PM
I currently have a 4-8* delta on my ECT/EOT, so I'm good there. Coolant filter is on the way. Truck runs great, just wanting some insight on what type of coolant it may be. Does anyone have a picture of there ELC coolant?
Old 12-06-2011, 01:28 PM
If it's orange-orange, something is a miss.
Either:
A. you had Ford Gold and somebody mixed in ELC combining the gold and red to make orange.
B. Somebody used Orange Dex-Cool in it.
Either way, not a good deal. In my opinion, flush that puppy to the point where nothing but clear water is running out and THEN get your EC-1 coolant in it.
Old 12-07-2011, 09:18 AM
I am in this same boat ... and now winter is here I talked to the local quick lube about doing a radiator flush and they said that I could bring in ELC. I am guessing I will have to do this a couple times before it is really changed. Once the weather breaks this spring I plan on doing my EGR Delete and a new oil cooler. Right now my delta is around 4-8 degrees I have seen 14 once pulling the whole rig in the summer months.
Am I being paranoid, should I just wait for spring to do anything?
Old 12-07-2011, 10:51 AM
I know winter is headed this way, but before you go to that much trouble, you may want to consider flushing the system. If the previous was mixing antifreeze, who knows what else they have done to the system. It won't help much to put good ELC in a dirty system. When I bought my truck a few months ago, supposedly it was converted to ELC. Not knowing how particular previous owners were. I started from scratch with a flush and CAT ELC. Know I know for sure. Good Luck.
Old 12-07-2011, 11:18 AM
Do you think a chemical flush is necessary with this? Or would just flushing with distilled water be ok?
Old 12-07-2011, 11:31 AM
IMO I would go with a chemical flush. Distilled water would help flush any solids (i.e. casting sand, contaminants) in the system but if you have any sludge/gelling water only would not do anything. Sounds like your deltas are good so your oil cooler is functioning. I flushed with Restore and Restore +.
I put a diy coolant filter on after the flush. Ran for about a week then cut open the filter. It had a green slime no one was able to identify. Two more filters later and I am clean....no green
Old 12-07-2011, 11:57 AM
If you don't have a coolant filter get one ASAP
If you decide to switch to an ELC style coolant, first of all, not just ANY ELC will do. It must have the CAT EC-1 rating.
There is a Shell Rotella ELC that meets that rating that is supposed to be "the best," but any CAT EC-1 rated ELC will work. International Truck dealerships carry the Fleetrite ELC which is CAT EC-1 rated and what they installed in the VT365 (International variant of this engine) from the factory. NAPA also sells a ZEREX ELC that meets the CAT EC-1 rating.
A few things to keep in mind:
One is that you need to purchase the CONCENTRATED form of the ELC, since the cooling system retains approx 50% of the total capacity when drained during your flushes. If you were to buy the premixed, you will never get to a 50/50 mix of coolant and distilled water.
Then next thing to be aware of is that you can not just drain out the Ford gold, flush only with distilled water and think everything will be ok. You are changing the coolant type, not just the coolant. To change coolant type REQUIRES that you flush using two chemicals. The restore and restore+ flushes serve two different purposes.
The restore chemical flush removes a film that the Ford Gold coolant deposits on the walls of the cooling system to help combat cavitation.
The second chemical, restore+ (same as the ford VC-9, only less expensive) is to remove rust scale build up in the cooling system. If the dealership used tap water (and I will bet you they did) you will have rust scale.
Should you skip the restore step, you could have a chemical reaction between the film left by the Ford Gold and the ELC style coolant. If you were to skip the restore+ step, you would be leaving the junk that clogs the oil cooler sitting there as a ticking time bomb.
With that said you could skip the Restore+ flush if your deltas are LOW 4-6* like is said you COULD your truck your motor---Here is the flush i did 48 gallons of distilled water 1/4 tank of fuel and 12.5hrs of my time if you want it done right you have to do it yourself.
Just remember if your temp spread is greater than 10* your coolers may be getting plugged and the Restore+ is not advised or you may plug the coolers you may be in trouble if you do or if you don't. it is a ticking time bomb.
This should help you understand the reason to ditch the Gold junk it can't take the heat. Gauges are a must to do this need to know EOT-ECT
Replaced oil cooler still difference in temps
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with distilled water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with distilled water. I used cardboard in front of the radiator because you have to get to 185* 190* for these products to work. Drive truck or run on high idle for 60-90 minutes just before you get back from your drive remove the cardboard this will help in the cool down same on the Restore+ flush. Drain and flush 3 or 4 times. or tell clean
Add 2qts VC-9 or 1/2gal of Restore Plus, top with distilled water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water while draining the block.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
new t/stat from Ford it should all come together (housing-t/stat-o-ring) in a box. The part number is RT-1169
Here is the Restore Product from Cummins dealer
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
2 stroker
Old 12-07-2011, 12:05 PM
To start with i would never take my truck to a quick lube for anything let alone Ford to do a flush. Your deltas are OK till spring get all your stuff together about 50 gallons distilled water 1 gallon restore (1/2 gallon used) 1 gallon Restore+ (1/2 gallon used) new t/stat, 4 gallons ELC CAT EC-1 Rated coolant then when it warms up
2 stroker
