Advantage of 58v FICM - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-05-2011, 09:46 PM Thread Starter
steed281's Avatar
My truck has a new FICM. Less than a year old. It's totally stock. What's the advantage, if any, to updating to a 58v unit with or without a performance tune in the FICM?
Thanks guys.
2004 F350 Lariat FX4 CrewCab Longbed
4" TB Exhaust w/gutted cat and no muffler
ARP Head Studs
EGR Delete
Diesel Site Coolant Filter Kit
SCT Livewire w/ Looney Wild Tune
Edge Insight CTS w/EGT
Blue Spring
Zoodad Mod
High-Idle
6.4 Banjo Bolts
Upgraded Turbo Oil Feed and Return
steed281 is offline
post #2 of 10 Old 12-06-2011, 05:23 AM
bfrank81's Avatar
Thanks guys.
None. Wait until it goes bad.
Brian
bfrank81 is offline
post #3 of 10 Old 12-06-2011, 05:55 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
I talked with the guys at ficmrepair.com and they said they stopped offering higher voltage ficm's because the overall reliability was sacraficed. They said they repair theirs to work at 48 volts, but with much higher quality parts, (and much harder to find, he added). He mentioned that the overall main board was less than capable of handling the higher voltage, or something to that effect. They say (swamps) that they'll run longer with their high quality 58v upgraded parts, so who knows. They do advertise that they run better, and actually make slightly more power, as the extra voltage starts to operate the Injector sooner, and longer. I wonder what that does for mileage?
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #4 of 10 Old 12-07-2011, 07:55 PM
06F250KingRanch's Avatar
Most people are getting an additional 1-1.5 mpg with swamps performance flashed 58v.
06F250KingRanch is offline
post #5 of 10 Old 12-08-2011, 03:11 AM
work&play's Avatar
Quoted: 2 Post(s)
You can just get your FICM tuned from PHP like I did and gain 1-1.5 mpg that I did.
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #6 of 10 Old 12-08-2011, 04:23 AM
Davey~do's Avatar
Agreed. If it ain't broke, dont mess with it. You can have the PHP performance flash put on your 48V if you so wish. But there's no point in upgrading to a 58V system until yours starts going bad.
David
2016 CCSB SRW FX4
Davey~do is offline
post #7 of 10 Old 12-08-2011, 04:51 AM
xjeeper's Avatar
I just refashed my 04 yesterday fromARZ2H00, to the PHP tune without inductive heating. this morning it fired right up after a 16 hr 25 degree soak. I will post when I have some miles on it. Without inductive heating your FICM should last longer, mine failed last winter, and I repaired it myself.
xjeeper is offline
post #8 of 10 Old 12-08-2011, 05:53 AM
Just when I'm ready to upgrade to a higher voltage FICM because of all the great things I've read here about doing such...now there's something wrong with that. It never seems to end.
neil is offline
post #9 of 10 Old 12-08-2011, 06:34 AM
Term3's Avatar
I'm thinking the reliability is due to perhaps to extra heat being produced by the FICM. I know some guys put some heat shielding between the engine and the FICM. I'm toying around with a force air cooling set up for my FICM, but now that winter is it probably won't get fabbed up until spring.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 10 Old 12-08-2011, 07:17 AM
xjeeper's Avatar
Vibration and lead free solder seem to cause the failure, heat just makes it worse.
xjeeper is offline
