Sorry I need the measurement of trucks with 4 and 6" lifts as well as 35s. I am trying to determine what lift I have. My tires are 35X12.50 Toyos open country on 20X10 Sandstorms -25 offset so I don't think 37s will really work with only 4".
Thanks Dik |
Your truck looks to be a 6" lift, I am running 35's and have a 5" lift.
Yours looks a little taller, I have 12" from the top of my tire to the fenderwell. You should be able to fit 37's on there! |
I measured 12.5 or 13 I can't remember right now and it is 36 outside so I aint goin outside. Thanks for the info.
Dik |
Any other measurements?
Thanks Dik |
I just measured again and I am at 11.5" so I guess I do have around 4-4.5" of lift. I don't suppose 37s with a -25 offset would work then.
Sucks cause my 35s look really small. Dik |
If you want measurements that mean anything in trying to determine your lift measure from the center of the hub to the wheel arch. That takes the tire out of it.
