Which leveling kit? Spacer on top or on bottom?
Im wanting to add 2" to my 6" Procomp Lift I have already. Im confused by the spacers that some mount on top and some on bottom. Any which one better or safer I should say? IN all my Jeeps, Fords I have had before they all go on top. Also whats the easiest way to install them? I know with Jeeps I used to undue the trackbar, drag link, shocks and spring mounts and lower the axle and compress springs if necessary. Is this the same concept? I also plan on making my own adj. track bar
I am running the 2.5 inch spacers under the lower spring pad. I have not had any issues. A friend of mine has the spacers on top of the spring and they squeak and make allot of noise. When I installed the lowers I just took loose the lower bolt for the shocks and let it drop down. Took longer to balance my tires than to install the level kit.
I bought them off ebay. This is the set I bought. Took me less than an hour to do but I do have a lift.
05-11 Ford F250 F350 4WD 2.5" FULL LEVELING LIFT KIT | eBay |
Alright thanks
