Coolant Filter Pics... What is this?
When I flushed out my truck I found alot of metal particles in the bottom of the drain bucket. Now after running for a few months the same particles are in the coolant filter. It looks like the block is rusting and flaking off but how could that be when it has had coolant in it the whole time? Any help? thanks
It looks like a mixture of casting sand, and gunk from inside your engine.
Also, make sure you aren't using a coolant filter with a Supplement Coolant Additive (SCA) as said filters are designed for much larger trucks and the additive can contribute to the development of this sort of sludge when used on the smaller 6.0L. I don't know what the rest of the guys will say but I'd want to flush my engine again if I was pulling out that much crap on an engine post-flush/ELC coolant install. |
Could be radiator little rust, can't really say for sure JER-1 |
which filter should I be buying, this one is one from napa, I'll find the number. I flushed last Jan and have put about 8-10k on it. Doesnt look like alot of gel for 8-10k but when I was flushing there was alot of rust particles... I just got my cts and its about 7deg delta. 190 ect 197 eot...
Here's a fairly comprehensive list:
Fleetguard WF-2077 Baldwin B5134 John Deere RE11992 Caterpillar 9Y4528 Cummins 3300721 Wix 24070 NAPA 4070 AC-Delco WF-108 Fram PR3383 Donaldson P554685 /ECF4085 Alliance (Freightliner) WF2077 CarQuest 89070 |
I used the napa 4070, just looked, when i was doing research i remebered the filter couldn't have additive in it...
What's the coolant in your degas bottle look like? Nice and clean? Did you do the whole 8-12 hr flush advocated here on the Org? Restore/Restore+ and the whole shabang? Or just a basic flush? |
I filled and flushed about 6 times with distilled water, used like 50 gallons of water while pulling the driver block plug and lower radiator hose, I used the vc9 in one of the flushes and the degas bottle looks good and clean
I'd flush it again if it were my truck. There's a ton of threads on this subject here on the Org. Do a search. Also, this is a pretty nice writeup: http://bit.ly/rE6Ghx |
