looking at a 6.0
when im looking at a 6.0 i want to monitor the temp. delta on it, and whatnot, can i do this with a normal code reader like something i would buy at napa or autozone, or even the craftsman one? and if its possible, can i monitor the FICM voltage with it? just need a little clarification on this before i get to lookin at new trucks.
No, a normal code reader will not work to moniter the PID's for this engine. For less than $170 you can get a Scangauge2 preloaded with the 6.0 x-gauges from Bullet Proof Diesel. I LOVE MINE !!
ScanGauge II Digital Data Monitor |
I have the scangauge and would not tow without it. I also tow heavy with the Hypertech and use it to protect my engine. Use to have an EGT gauge and the connection broke 2 years ago and while towing I never saw any alarming temperatures.
Get the ScangaugeII and install a good EGT gauge and your truck will thank you for it. The scangauge can indicate alarming data way before it becomes a problem. It replaces the gauges in the fancy dash that I never look at because they are just ediot gauges. |
is the scangauge just a monitor, like i can use it when i test drive used dealers 6.0s?
I would say you could, as long as you program it properly for the year and displacement of the engine in the truck. That's a damn good idea! Wish I would have thought of it before my purchase!
it just plugs into the OBD II port? and i can program it to any 03-07 6.0 i look at? i can monitor the coolant temp delta on it too? the EOT and ECT ? just trying to clarify.
I am very new to the diesel world, so I have extremely limited knowledge. But, yes, you can plug it into that port and it does monitor up to 4 different things on the screen at the same time. I use it mainly to monitor the difference between the oil and water temps.(EOT and ECT)
what should the difference be between EOT and ECT, to tell if i got a bad oil cooler or not?
When the WCT is at 190F, the WOT shouldn't be more than 15F higher. I checked after cruising at 60 mph for 5 miles or so to make sure everything is warmed up enough. My temps vary around 8 degrees on the average at 60 mph. Outside air temperature I found will effect the oil temp, also.
