Heated Seats Not Working - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-03-2011, 06:24 AM Thread Starter
badyota82's Avatar
Ok finally got the opportunity to check this out. Turns out, I have power to both seats. Did a continuity test on the heating pads. Seat backs are good, seat bottoms are not. Pulled passenger seat cover off to find burnt wire in pad. Question is, is there a better, aftermarket pad that I could install that will last longer? Truck is only 5yrs old. Wifes monte Carlo is 8 yrs old and seats still work AWESOME in it. Or am I stuck with OEM heating pads? If so, anything I can do to protect them better so sliding/moving around on the seat doesnt cause the same problem in dealing with now?
Thanks for the help guys!
2006 F250 Lariat FX4:
MBRP 4" Turbo Back Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle Mod
Dieselsite Coolant Filter
58v Swamps FICM
SCT w/ Matt's SRL Tune
6.4 Banjo Bolts
CCV Mod
2006 F250 Lariat CC FX4
Current Mods:
4" MBRP Exhaust
58v FICM w/ performance flash
Blue FPR Spring
SCT w/ tunes from Matt (SRL, 8k Tow, Unlim. Tow)
Edge Insight CTS
1200rpm High Idle
Coolant Filtration System
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
Sold: 1997 F250 PSD 4x2 5 speed
badyota82 is offline
post #2 of 5 Old 12-03-2011, 07:53 AM
HawaiiBake's Avatar
Quoted: 3 Post(s)
I fixed mine with a soldering iron a year ago and haven't had any problems since. I have a thread on here somewhere about it. If you allready have the cover off you are halfway there. Did you allready undo all the godforsaken hog rings?
05 F350 Lariat Crew Cab Short Bed
ARP's
EGR Delete
6" lift with 37's
Currently under the knife doing a 2016 body conversion
HawaiiBake is offline
post #3 of 5 Old 12-03-2011, 02:52 PM
Quoted: 3 Post(s)
HeatedSeatKits.com - The Future is Warm they work great high and low
dporter is offline
post #4 of 5 Old 12-03-2011, 04:06 PM Thread Starter
badyota82's Avatar
Well, I did have the hog rings undone, but put it all back together since figured I wouldn't be getting around to fixing it anytime real soon. They are a HUGE pain in the arse!!
dporter I'll check out that link. Thanks
Blue FPR Spring
Edge Insight CTS
58v Swamps FICM
6.4 Banjo Bolts
CCV Mod
Current Mods:
4" MBRP Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
post #5 of 5 Old 02-11-2012, 09:08 AM
Quoted: 3 Post(s)
you can replace hog rings with small zip ties. Much easier to use.
dporter is offline
