Turbo Vanes Sticking??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-29-2011, 04:59 PM Thread Starter
Beef52751's Avatar
My truck has been sitting ALOT in the past 6 months. Ive run maybe 3 tanks of fuel through it mostly on short trips in the past 6 months, that being said i am pretty hard on it when i do drive it. I jumped in it tonight and it wouldnt build more than 25 PSI on my SRL+ Tune. It turbo farts when it shifts, when i accelerate hard or when i try to build any amount of boost over about 20. I noticed it has turbo farted in the past when it shifts and just figured it would come out of it by driving it but it has gotten much worse. Do i need to pull and clean the turbo???
Thanks
Bryan
The truck is an 03 6.0 auto BTW
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #2 of 6 Old 11-29-2011, 06:40 PM
Firefighter Member
Shockley6.0's Avatar
yes on needing to clean....mine hasn't been sitting but I know it needs cleaning.....but forsure you need to clean it.
Shockley6.0 is offline
post #3 of 6 Old 11-29-2011, 06:46 PM Thread Starter
Beef52751's Avatar
i was thinking it needed cleaned before i parked it, i think the sitting was the straw that broke the camels back per say.
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
post #4 of 6 Old 11-29-2011, 08:26 PM
colinmitchell111's Avatar
I just bought my truck and mine was doing the exact same thing. I pulled my egr valve and checked that because it was the easiest thing to do and it was nasty. I ran to the dollar store and spent $5 on a can of carb clean and pack of wire brushes and a half hour later I was back running. Feels like a completely different truck now. I figure if I have any more issues in the future I will clean the turbo or check the egr valve again. Don't go tearing into a major project like pulling the trubo when it could be something alot easier. Hope that helps, here is what mine looked like before I cleaned it.
04 F250 SC SB auto 4x4
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
Sinister coolant filter kit
Upgraded blue FPR spring
CCV Dump
Warn locking hubs
SCT with Looney
colinmitchell111 is offline
post #5 of 6 Old 11-29-2011, 08:42 PM Thread Starter
Beef52751's Avatar
i have an egr delete so i doubt it is that, thanks though
I returned the truck to the stock tune and it runs pretty good, i can hardly get it to turbo fart, but it does seem a little laggy from a stop, but it has been almost a year since driving on the stock tune so maybe its just me??? I have a hard time believing that the tune is the problem since i have been running the same tune for almost a year now with absolutely zero issues. any input???
Thanks
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
post #6 of 6 Old 11-29-2011, 11:20 PM
sbarbee54's Avatar
Clean it and replace the unison ring why you are in there. Also might as well get new turbo hardware and updated drain tube and supply line. I just did this plus put the 6.4 banjos on and the new fuel bowl and blue spring mod. Have fun it is pretty easy.
2005 F-250 CC SB FX4 Lariat 6.0
SCT Live Wire Tunes By Quick Tricks
MRBP 5" Straight Pipe
Banks Intake
GlowShift 4 Pillar/4 Mirror Pod
Kenwood DNX8120/Diamond Audio System
10" Sky Jacker Lift W/Procomp Rezies
Amp Steps/TopGun Customz Dual Fox Stear
Yukon 4:56's
Zoodad Mod/6.4 Banjo Bolts/Blue Spring Mod
PMF Trackbar/Draglink
20" Helo Maxx 8's W/ Toto MT 38X15.50R20's
sbarbee54 is offline
