ScanGauge Xgauges Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-29-2011, 10:54 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Can someone help with programming steps to add the EOC and ETC gauges to the scan gauge?
I want to see how far apart my Oil and coolant are running.
4.06 Version.
Denny
colonel angus is offline
post #2 of 8 Old 11-29-2011, 11:05 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
ECT is already in. It is fWT.
Go to YouTube and do a search for "Entering Xgauges " I did a video while entering. Or search for "amdriven2liv ". I have a couple on there.
The manual is a help also.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #3 of 8 Old 11-29-2011, 11:29 AM Thread Starter
Quoted: 2 Post(s)
Thanks i looked at you tube, do i use the same values as you or where can i get the values without the digit. Is there a list someplace for other values as well?
Denny
post #4 of 8 Old 11-29-2011, 12:55 PM
Quoted: 4 Post(s)
Go to Scangauge II website. Click on xgauges.Look for the Ford list.
post #5 of 8 Old 11-29-2011, 12:57 PM
Quoted: 4 Post(s)
I am away from my computer. I will check back here this evening and give more info.
post #6 of 8 Old 11-29-2011, 12:59 PM Thread Starter
Quoted: 2 Post(s)
Thanks for all the quick replies, i went to their site and got all the info i needed.
Seeing 209 on the Oil and 195 on the H2O so it appears i'm in need of a oil cooler.
Now i'm off to Bullet Proofs website.
Still don't trust Ford "new" improved OEM anything, not even an antenna.
Denny
post #7 of 8 Old 11-29-2011, 06:59 PM
Quoted: 4 Post(s)
Denny
Let sit over night and get a cold read on the gauges to verify the gauges are near each other in temps.
post #8 of 8 Old 11-29-2011, 07:32 PM Thread Starter
Quoted: 2 Post(s)
They start out close, stay that way for most of the drive then EOT climbs the longer i drive.
For the most part they stay under 200, especially Water hovers around 193 - 195
The main issue is to get it to stop puking.
Once i have the new cooler in place, i'll flush it with Restore and possibly refill with elc? coolant.
Also have a sinister coolant filter to go on.
Denny
