Level Questions??? - Ford Powerstroke Diesel Forum
Old 11-29-2011, 06:16 AM
Question Level Questions???
I am looking at getting my truck level. I was thinking about going with the 2.5 level kit and the f350 blocks.
Question 1: What front end adjustments will need to be made after the block is installed? (axle wrap?)
Question 2: If i plan to get air bags eventually, would there be a need for the f350 blocks?
Thanks,
Clint
Old 11-29-2011, 06:47 AM
War is the answer!
Well, you have a fx4 so I would not do blocks if you plan to be off road with it. I think you can go 2.5 without having to worry about adjusting anything. I did a 2" on my f350 and that's so when I tow the @ss won't sag as much. The f350 blocks in the back you would need until you get the bags because otherwise the @ss would sag.
Old 11-29-2011, 08:21 AM
so the f350 blocks and fx4 dont mix? Why is that?
Old 11-29-2011, 08:39 AM
War is the answer!
It's not that its that you dont want blocks on the front end becouse they can kick out and you can damag your truck. I have only seen it once but I hear about it all the time. Its better to do a shackle or add a leaf lift IMO
Old 11-29-2011, 08:55 AM
I see, well back to the drawing board i guess. Sounds like the best setup would be add a leaf and do the airbags in the back.
Old 11-29-2011, 09:07 AM
War is the answer!
I personally like my add a leaf but would consider the shakle too.
