How to get SCT x3 to read eot vs ect
I dont know if this has been covered on here but i just got done doing it, hope it helps someone;
first update the driver for the x3 (easy to follow steps on SCT's website), then download Live Link from the website as well (version 6.5 is what i have) Once you have Live Link open as well as the SCT hooked up to PC via USB click on commands (on gray colored bar along with stuff like file, view etc) Then click on Configure Datalog Items for strategy....this will bring up a box prompting you to enter the trucks strategy (mine is VXCF1D6), enter it then press OK it will pop up a list of areas to choose from....click on enviroment.....choose eng oil temp, eng coolant temp....along with any other items you wish to monitor. with my strategy there were over 1000 different parameters to choose from so pick the ones you want.....not sure how many it can monitor at once. Once you choose your parameters (at least eot and ect) click OK Then click on File at the top and choose Add Datalog setup to X3/Livewire ....You now have the new datalog on your tuner. Somewhere in those steps it ask you to name the file (cant remember exactly where but give it a name) Plug SCT into the truck and go to setup new datalog and choose the file that you named....and now you can see if your oil cooler is trash! I updated the firmware prior to doing this, not sure if it is needed or not Hope this helps someone, I have analog gauges and kept borrowing my buddies CTS to check deltas, now i dont have to |
nobody else has done this?????? most people on here have the sct i thought....good info!!!
I don't even know what this thing looks like, but from all my reading I get the impression people are buying a ScanGauge or Insight to do this even though they have the SCT. If I'm reading it right. You may have something there.
Its good info, the first day you posted it, I saved it to my subscriptions for the new members. Thanks.
The issue is, the read out is small and hard to keep an eye on with the X-3/SF3 while driving down the road. It's a cheap/easy way to check your ECT/EOT delta if you already own a SCT. |
I use my sct to read eot and ect...when I need to
