Trucks going in to get fixed - Ford Powerstroke Diesel Forum
Old 11-27-2011, 08:43 PM
Well truck goes in to get fixed in a week finally and getting all the parts installed. Truck has a plugged oil cooler and the thermostat is stuck open. Currently the truck has Edge CS and 4" MBRP turbo back straight pipe exhaust with 6" tip.
Here is a list of parts that are going on truck
SCT X3 Currently with Spartan tunes but will upgrade to Erics tunes
Coolant Filter
Oil Cooler Rebuild Kit
Fuel Pressure Spring Upgrade
Turbo Mounting Kit
Thermostat
Intake Gaskets
6.4 Banjo Bolts
Egr Delete
After this the truck is gettin 315/70/16 Nitto Mud Grapplers and a Leveling kit.
Have decided that I want to run a stack so I am peicing together a kit and a 7" Black Miter cut and keeping the rest of the exhaust I take off incase the baby doesnt like the stack I can put it back on.
Old 11-28-2011, 09:12 AM
I would be thinking about a coolant flush before it goes in also i would be looking at Dummy plugs and STC Kit.
2 stroker
Old 11-28-2011, 09:49 AM
Already did the coolant flush 2 weeks ago and eveything was upgraded last winter and turbo cleaned when hpop was installed oh and also running cat elc
