Codes after egr delete. - Ford Powerstroke Diesel Forum
Old 11-25-2011, 07:03 AM
After driving the truck for the first time since the egr delete i now have 2 codes. P006a ( mass or volume air flow correlation) And p0113 (iat sensor circuit high input). I checked the connections and everything was plugged in. Where should I start?
Old 11-25-2011, 07:21 AM
MAF not plugged all the way in? Sounds like an issue with the wiring to the MAF.
Old 11-25-2011, 07:31 AM
Yes. Everything is tight
Old 11-26-2011, 04:33 AM
Bump
Old 11-26-2011, 05:49 AM
Very odd. I would try disconnecting the batteries for a minute, reconnect them then see if the codes come back. Perhaps some brittle wiring got damaged during the delete install.
Old 11-26-2011, 10:07 AM
For an egr delete those are not the normal codes to pop up. Really check your work, if it is not as simple as a connection, it maybe from damage during the work performed.
Old 11-26-2011, 11:52 AM
I tried to clean the IAT sensor. Maybe that did it. I cleaned it with diluted purple power. The MAF sensor I did nothing to. I cleared the codes, we'll see if they come back.
Old 11-27-2011, 06:13 PM
Codes came back and wiring looks good. Is there any way to test the sensors?
