Shared Knowledge is a MONEY saver - Ford Powerstroke Diesel Forum
Old 11-23-2011, 06:55 PM
New here But man have I learned alot .Been reading and not posting just going out and trying the wealth of knowledge here. I have learned how to change a 6.0 without the cab off its easy if you got the tools.I pulled out the motor on my first 06 6.0 that went down due to major issue with oilcooler.Oil coolant mixture thoughout whole motor.Replaced this with a 04 6.0 I got for 0 dollars,dealership said it wouldn"t fit and wanted $22.000 to put new in thats when I found this place and succeded with the swap all by myself turned key and it ran Happy Days.Been here since.Then after that job they all died one after another,05 super cab-egr,and cooler fixed with knowledge from here.06 dually camshaft and rollers,turbo,still down looking for used 6.0 as motor out already.05 dually FICM? maybe oil pressure on the search reading here.48v on ficm,icp unplugged no start yet.The one I put the 04 6.0 in the cooler calved and think it was cause of all the oil in system prior from the major issue but got it half tore apart now,waiting on parts. I just want to say without this forum I would be about 40-50 G into these things but no more.I will get them running with help and info from here and will post progress.Oh ya they all are up in the 200-350km range.Keep up the good work here THANKS
