Camshaft sensor and no start question - Ford Powerstroke Diesel Forum
Old 11-23-2011, 04:04 PM
Just changed the CMP sensor in a buddies 03 stroker due to the motor cutting out or missing causing it to die. It never threw any camshaft codes but figured the symptoms pointed toward CMP sensor. New sensor is installed but now the truck will not start. Truck turns over but will not fire. Now I am wondering if the original prob was in the wiring from the original CMP to PCM and not the acutal sensor. Is there any way to check the wiring for continuity or proper voltage?
Old 11-23-2011, 04:29 PM
Powerstroke Techie
Easiest way to tell is to monitor data. You will be looking for the PID "FICM sync" If this changes from no to yes then the cam and crank sensors are working fine.
I've only replace one or 2 cam sensors in these trucks. They don't have nearly the same issues that the 7.3 had. Not saying it's not an issue, but they will usually throw codes for it.
You getting any codes now? Did you make sure the sensor is pushed in all the way?
Old 11-23-2011, 04:41 PM
Sensor is all the way in and harness clicked in place. Nothing was removed to touched except the sensor and harness. The only montering device i have is an edge insight and it only reads FICM volts (which is 48). Not thowing any codes at all. Should the old CMP sensor be covered in oil or would that be an indication the oring failed?
Old 11-23-2011, 04:49 PM
Powerstroke Techie
Possibly an indication that the o-ring failed. Was in oily inside the actual connector? You can ohm out the old cam sensor and see if it was actually working. I don't remember the exact ohm reading but if you get an infinite reading then it's definitely bad.
It should have logged a cam sensor code if that was the issue and you've cranked on it long enough.
What's FICM voltage at? What is ICP pressure at while cranking? Pull up RPM's and see if it's reading any RPM.
also, I got the 8mm bolt snugged tight so I am sure the sensor is seated all the way......
Old 11-23-2011, 04:55 PM
FICM voltage while cranking is 48.5. My Insight only displayes ICP voltage and with the key on showed .1 and while cranking varied from 2.0 to 2.3. I cranked for 15 seconds and only code that shows is P1000 so I know the computer is trying to run test on all sensors. Not for sure what you mean when you ask about RPMs
Old 11-23-2011, 04:58 PM
Feedback Score: 3 reviews
Have you ran down Bismic's list.
Troubleshooting a No-Start condition
Since its an '03, my first guess would be ICP sensor leak and/or ICP wiring. Second guess would be IPR.
But without a scan tool, we're all guessing.
Old 11-23-2011, 05:07 PM
Powerstroke Techie
I was saying to try and pull up engine rpm on the insight and see if it's showing rpm's. If so, then the PCM "should" be seeing cam and crank sensor readings. But I've noticed that if the cam sensor is not reading the crank sensor will still relay rpm to the PCM but it still won't let it fire.
So, in other words see if you can at least monitor rpm thru the insight.
A reading of 2.0 volts ICP pressure should be enough to run. KOEO ICP sensor voltage is .24, which equals 0 ICP pressure. .84 volts ICP pressure is 500 psi. So if you are reaching a reading of 2.0 volts then you are well above 500 psi ICP pressure and ICP pressure shouldn't be an issue, unless you have a severely biased ICP sensor which I doubt.
Old 11-23-2011, 05:08 PM
i will check most of that. But the truck had no starting issues until I changed the CMP sensor. Now it just cranks but no fire. Does not even try to fire. So unless it was a crazy chance the ICP or IPR went bad at this exact moment I pretty sure it has to be related to the CMP or wiring.
That is an excellent no start list with a ton of info though!!!
Old 11-23-2011, 05:14 PM
Reading 140 - 160 RPM while cranking. That seems low but I have never monitered RPM while cranking....
Also, Batteries are now weak and on a charger. Batteries showing around 12.1 volts so not sure if that would slow the cranking down
