EGT temps took longer to come down today?
I have a CTS and EGT probe. Have had them in for over a week and have been watching them closely as we all should. Turns out I was idling my truck much longer than needed before I got the CTS to bring the EGTs down. Anyway, up until today, I could pull in from wherever I had driven and it only took 30-45 seconds normally for my EGT to drop to 350. Today the high was 62 (not hot by any means), and I had to run an errand (to pick up some fuel additive) this afternoon. It's only 4-5 miles from work. I drove there, pulled up, put in park and waited for my temps to come down. They trickled down MUCH slower than normal. I didn't hot rod it on the way there. 2 miles of it on the highway at 70mph. It finally got into the 370's, briefly hit 368, then back into the mid 370's. I waited several minutes and they never got lower. I finally turned it off, went in, got my stuff and went back to work. Same thing. On the way home, same thing.
I had the heater on. Turned the temp up to 90, fan on full blast, didn't make a difference. Turned it down to 68 and fan on low, no difference. Why would it cool down slower today? |
Did you have your AC or defroster on? It will take a bit longer running your AC pump.
Nope, no AC, just the heater. I did have it blowing on defrost though.
The vent it's blowing out of shouldn't matter. Only that the heater is on and AC is off to pull heat out of the coolant.
Not sure about the 05's but some vehicles run the ac when in defrost... Just a thought.
If you had your defrost on, your AC pump should be running to dry. When it is warmer out, my EGTs take a bit to come down below 400 with that pump running.
Check your boost tubes(boots mainly), manifolds, and up pipes and see if a small leak has developed. won't hurt anything and won't take too much time.
I will turn defrost off tomorrow. Going bow hunting early in the morn. Thanksgiving family tradition. I've got a charged air tube in the mail from a single alternator truck. When it gets here I'll check the rest of the charged air tubing.
I did have my first diesel race last night, another F250, on the highway from 70mph...smoked him. Maybe I blew a tube/hose... |
BTW - that truck is great looking!
