cleaning the intake...? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-23-2011, 05:13 AM Thread Starter
I am removing the intake manifold to do the EGR delete and oil cooler. From looking in the EGR valve there is a lot of black wet soot in the intake. I have looked on here and some people say to clean it, some say dont worry about it. Should I take it in somewhere and have it cleaned, I live in a small town and dont know if there is somewhere in town that will clean it? Do I soak it in degreaser and pressure wash it and get it as clean as possilbe? or just leave it alone and reinstall?
Thanks,
Will
2004 F-350 Lariat Crew Cab FX4, Dark Grey, T3 Front and Rear replacement bumpers, Fumoto valve, Diamond plate running boards, Zoodad mod, Dieselsite coolant filter w/ ELC, Blue Spring Mod, LED cab lights, Edge Insight CS, SCT SF3, PHP FICM/ECM rollback, Sinister EGR Delete, 6.4 Banjo Bolts, ARP head Studs, Zone Offroad Leveling Kit, CCV Mod, Straight Exhaust, S&B intake, Atlas 40, 295/75R16 BFG,
fishmanwill is offline
post #2 of 5 Old 11-23-2011, 05:36 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Clean it.
I used a parts cleaner and just let it run into each runner for about 10-15 minutes and into where the elbow attaches over night. Then it went to the self-serve car wash for a pressure wash. The cleaner the better.
Now a question for you.
What is your opinion of the PHP ECM/FICM rollback? Worth it? Did you opt for the "tuned" version or just left it stock?
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 5 Old 11-23-2011, 06:07 AM
Chapter Director
psd_va's Avatar
i had mine off and decided to clean it used some degreaser and cleaned it up the best i could which wasn't as good as i would have liked it to be. if you can first choice would be take it to a machine shop and have them dip it over night and clean it. but if you decide to clean it yourself make sure you have a good pair of gloves that go atleast half way up your arm casue the soot will stain anything and everything including your skin for about a week if you get enough on you.
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 5 Old 11-23-2011, 06:09 AM
Chapter Director
psd_va's Avatar
o and wether you do it or you find a shop to do it make sure you blow out the fiiting that the hose for your map sensor to make sure its not clogged and mess up your readings and in turn give you some driveabilty issues.
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #5 of 5 Old 11-23-2011, 06:23 AM
Quoted: 6 Post(s)
You definately want to get it clean! IMO that is one of the most important parts of the job.
a2elvis is offline
