Has anyone smogged a "DELETED" 6.0 in California?? - Ford Powerstroke Diesel Forum
Old 11-22-2011, 06:58 PM
That's the question. Or anyone who has first hand experience and has been through the smog process in California?
I'd like to delete that cooler and just be done with it, BUT, don't want to be standing there with my d**k in my hand when someone says, "the computer says your EGR cooler ain't working".
I mean it's a lot work to perform twice and money to pay out. I'd like to just eliminate the problem all together. I like the Bullet Proof EGR cooler, but would much rather eliminate the whole thing.
Old 11-22-2011, 08:48 PM
had mine smogged a few months back , its really only a visual test .they popped hood looked around a bit fired it up reved it it up three times lokkin for black smoke walla your done !!!
mind you i still had programmer in just set to stock that day ,did not put cat in but had one lined up and when you pop hood on shroud my banks sticker jumps out at you !STROKEDIS
my buddies truck just passed also no probs !
Old 11-22-2011, 09:33 PM
What part of CA are you in where they did nto even check for a cat
Old 11-22-2011, 09:45 PM
Send a message via Yahoo to navyeoseabee
Which part of Cali? i did smog a year and half ago and they did a visual under the hood, i don't think they would notice the egr delete, but they hooked up the sensor to the exhaust tip,and did the throttle snap test to see the blcak smoke.
i am about due so we will see.... i would like to see the reading of the smog crap with the delete....wish i had my oklahoma tags stillon it!
Old 11-23-2011, 01:14 AM
minimize your idle time, keep the coolant flushed and in many cases, the EGR will work just fine. its the guys that just have to idle for .5 hour to warm up and every excuse during the day that have the most egr issues. even at -30 my idle time is 3-5 minutes tops
Old 11-23-2011, 01:52 AM
Exactly...................I only idle enough to get my engine somewhat warmed (About 3-5 minutes max) so diesel isn't condensating on the cylinder walls when I step on it. Usually, I'm in gear, shortly after it hits high idle. I don't have a cooler or EGR, but I figure that cool exhaust laden with fuel can't be doing that VGT Turbo any good!
John
Old 11-23-2011, 07:46 AM
In Cali, unless you have a "friend" or the techs at the smog check are lazy, ignorant, or apathetic, you will need your EGR cooler and cat.
There are also many counties in Cali that only require a smog certification only on transfer of ownership. For example, I live next to one of those counties and some people I know register their vehicles with a friends address or get a PO Box in the county next door. Just a thought.
Old 11-23-2011, 08:16 AM
ok guys i live here in discovery bay but had the smog done in brentwood , ive been taking all my cars and trucks to him for awhile . by no means is he lazy or incompetent he just tells me its are wonderful states way of getting more money outa us. really guys its just a visual test till i think he said 2013 then all the bs hits the fan . STROKEDIS
Old 11-23-2011, 08:27 AM
There is visual for the cat, egr vavle, egr cooler, CCV.
NORMALY, you will not pass if one of those is not on the truck.
I blocked my egr cooler 100% and the CEL and codes are blocked by the innovative tuning. I have my egr vavle still on the truck plugged in but it is also off(closed) form the tuning.
Look at my sig for a non-tuned/stock truck what wants to do an EGR mod.
Old 11-23-2011, 08:31 AM
I need a place that will look past no cat
