EGR maintenance - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-22-2011, 11:48 AM Thread Starter
cowens677's Avatar
Quoted: 17 Post(s)
EGR maintenance
I recently bought an 05 powerstroke and have been reading about their problems on this forum and others. Do most owners check there egr valve regularly (so ones that still have it) and do you do a maintenance every so often? My truck has almost 55000 miles and I am sure it has never been cleaned, so I was probably going to do that. But if I pull it do I have to get new o-rings or can I keep the old ones if they still look good?
cowens677 is offline
post #2 of 15 Old 11-22-2011, 11:59 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I've read where some members clean it every other oil change, so it might be a matter of personal preference.
The o-ring and gasket kit is only like $12, but I don't see why you wouldn't just reuse the old ones, as long as they are in good shape. Maybe keep a gasket kit on hand, just in case you decide to clean the valve and the dealer is closed (Murphy's Law).
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 15 Old 11-22-2011, 12:07 PM Thread Starter
cowens677's Avatar
Quoted: 17 Post(s)
Ya I figure I should probably by the o-ring kit just in case. Well I will check her out, give her a good cleaning, and then in a few months delete all together.
post #4 of 15 Old 11-22-2011, 02:15 PM
Quoted: 2 Post(s)
Have an o-ring kit handy just in case one tears when you pull it out even if you plan on reusing them.
2016 F350 Platinum
ralderman is offline
post #5 of 15 Old 11-22-2011, 03:05 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
I have an early 04 so I just unpluged mine. No more worries.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #6 of 15 Old 11-22-2011, 04:09 PM
Powerstroke Techie
Lilpooh's Avatar
BAD IDEA!! With certain year trucks and certain strategies, unplugging the valve may cause clutch fan not reaching full rpm, and disabling the VGT vane cycle at idle.
Lilpooh is offline
post #7 of 15 Old 11-22-2011, 04:24 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
What would the EGR have to do with the clutch fan? Do you have documentation on this you can share or is it hear-say?
WarChild is offline
post #8 of 15 Old 11-22-2011, 04:29 PM
Powerstroke Techie
Lilpooh's Avatar
Sure can, the first link comes from a Ford tech about the fan.
http://www.ford-trucks.com/forums/97...egr-valve.html
And this link is what I and others on here have noticed.
http://www.thedieselgarage.com/forum...d.php?t=102838
Lilpooh is offline
post #9 of 15 Old 11-22-2011, 04:34 PM
Powerstroke Techie
justinmix's Avatar
I only unplug/remove the valve on pre 06 trucks if you use a tuner and disable the EGR function that way. If I do an EGR delete on a pre 06 truck and don't install a tuner I always leave the valve installed and plugged in.
While I can't personally come up with hard "facts" for it I've read of numerous issues that have stemmed from this. So I would rather play on the safe side and leave the valve plugged in.
justinmix is offline
post #10 of 15 Old 11-22-2011, 04:38 PM Thread Starter
cowens677's Avatar
Quoted: 17 Post(s)
I read those too, so if I delete do I have to leave the egr in and sct tuning to work correctly in my 05 or can I remove the egr, use the block off plate with sct tuning.
