Originally Posted by Jayson41
Well it's insight time, I want to keep the factory grab handle on the driver A pillar. You guys who already have them installed did you have to get rid of your handle? Also is there an over the rear view mirror option? I see there is one made for the attitude, if i get that and the mounting plate for the insight will it work?
View Images of Edge Mount Pods
The goal is to use it as a monitor only, no power mods to my truck just pulling to the trailer and it does fine.
That is how I have mine setup, and you can also see the brake controller. One thing I did was to unscrew the OBD2 harness from the lower mount and relocated it behind the dash. It is very easy to hit it with boots on or regular shoes for that matter. You can see the thick black wire running down the dash that mates up with the brake controller wiring, but a couple of them belong to the Ipod stashed behind the CS in the storage bin.
You could easily fit a CTS on the type of mount that I have and it does not obstruct anything. Also, I have less chances of glare and the screen is easy to read from the driver's seat.
