Rebuild engine or install used engine? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 11-20-2011, 10:30 PM Thread Starter
Just picked up an 06 f550 and pulled engine, found head gasket was blown on six cylinders. Rust has it locked up on cylinder walls around pistons. Entire cooling system was clotted up. About 2 quarts of coolant came out with oil when I drained it. So here is my deal, should I spend the money to have this engine rebuilt. Or I can get a used engine from the salvage yard for a little less.
Six point ooh is offline
post #2 of 20 Old 11-20-2011, 10:59 PM
Country Mav's Avatar
Quoted: 2 Post(s)
If I were in your situation, I'd probably look for a decent used engine, have it checked out, have the heads checked out, New OEM head gaskets, have it studded, EGR deleted and Oil cooler changed (Blow through/Clean any parts of the cooling system that you can access) then flush everything once you get it installed... After that, you'd probably have a pretty good engine on your hands... Hopefully for less money than it'll cost to rebuild your's. It sounds like it needs a serious overhaul. Like I said, this is just what I would think about doing if it were me- Good Luck to you! Keep us posted!
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #3 of 20 Old 11-21-2011, 11:33 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Reman 6.0, $4495
Please
You could save the life of a sick child
NYC F-350 is offline
post #4 of 20 Old 11-21-2011, 04:08 PM
if you have the capeabilty id rebuild it. id mine for less then $3500 all parts and machine work.
stnghlr is offline
post #5 of 20 Old 11-21-2011, 04:21 PM
Galaxie's Avatar
Im all about building motors and LOVE doing it. However if it was me, I would find a used or reman 6.0 like NYC posted. What would be ideal is finding just a short block and I would bolt on my own heads, injectors, and turbo.
Personaly, I would'nt do a Fummins. I know it will be sugested here but the more I play with these motors, the more I relized they are freaking great.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #6 of 20 Old 11-21-2011, 04:33 PM
CCSBD's Avatar
Originally Posted by NYC F-350 View Post
This looks like an awesome deal for the price. It has everything ready...studs, egr delete, new oil cooler!!
***SOLD***
'04 CrewCab ShortBed 6.0 4x4
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
Sinister Coolant Filter
Recon Smoked Cab Lights
SCT X3 Tuned by Innovative
4" MBRP SS Turbo Back Exhaust
ISSPRO EV pyro, trans, boost guages
CCSBD is offline
post #7 of 20 Old 11-21-2011, 04:47 PM
kdogg85's Avatar
Yeah that ain't bad considering all the stuff done already. If money wasn't an issue, what better time to make a pulling monster. Or, I wonder if a 6.4 could find its way between the framerails and work?
If you could rebuild it for less, it may be better because you would know exactly what's been done, and who done it.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #8 of 20 Old 11-21-2011, 10:36 PM Thread Starter
I had a chance to stop by the salvage yard today. They had a very clean 06 with 83k and are asking 5k for the entire engine. We hooked up the batteries and it fired right up. Sounded great with no smoke. I told them I would get back to them on it. So this might be the rout I go. This truck I have is a out of lease vehicle from the new Mexico oil fields, (it was rode hard and put away wet) lol. I plan on installing a total solution kit and was wondering if aftermarket head gaskets are any better than the oem? Anyone had good luck with the h s mini maxx tuner? Any other mods I sould while the engine is out?
post #9 of 20 Old 11-21-2011, 10:57 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
5K is high for a junkyard engine.
Try Car-Part.com--Used Auto Parts Market and check out what is in your area. Junkyard diving from the comfort of the chair your parked in right now. Love that site.
At the bottom, select "distance" and enter your zipcode. It will sort all the engines by the distance from your area code.
For 5 grand, I would go with the engine I linked above. It comes with everything you want to do to it already done.
If you go the other way, the stock Ford gaskets have a much better reputation. The gaskets were never the issue, it is the stock head bolts that stretch due to a failed egr cooler (caused by a plugged oil cooler, caused by lack of maintenance on the coolant) that makes the head gaskets fail. ANY head gasket in that situation fails, period.
Please
post #10 of 20 Old 11-22-2011, 07:44 AM
Quoted: 2 Post(s)
That's a great price on a reman engine.... Thanks for the link! Filing that away for future reference...
Sinister EGR Delete
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
EGR Delete
FARM TRUCK
