STACKING LIFTS?
I HAVE A 2006 F250 WITH A 8" PRO COMP LIFT. CAN I ADD A LONGER COIL TO GET A FEW MORE INCHES?
im pretty sure you would be ok to add a 10in coil but i wouldnt go any bigger than that without replacing the shocks
ur steering wheel might be off if its set strait right now without adjusting components id just add a 2.5'' leveling spacers
THE ONE I HAVE HAS A 6" LONGER COIL AND A 2 IN SPACER AND I WANT TO TAKE THE SPACER OUT. RATHER IT BE COIL ALL THE WAY.
THE STEERIN IS STRAIGHT FOR NOW. AFTER I PUT THE NEW PITMAN ARM ON I HAD TO ADJUST IT IN SO IT CAN GO OUT TO MAKE UP FOR IT.
yeah than id say just go with a 10'' coil spring and as long as u can adjust the bar i think it should work
You talking about the track bar (panhard bar)
yes because thats going to adjust your steering wheel also brake lines might b a factor in this im not sure, sway bar end links might have to be raised also i dont know what it looks like under your truck its all about lining everything back up so your axel isnt shifted over to the drivers side
I've already added longer brake lines they have more than enough for 2" and the sway bar is long enough also. guess its just a matter of trying it all now. i've heard of a few ppl doing it so maybe it'll all work out.
