Is this good or bad
Looks like your rear axle vent tube fell off the clip inside the framerail.
It was probably hanging down close to the ground so somebody tywrapped it up. Cut it loose and put it back up where it goes. |
Ok thanks so it goes to the framerail.. Ill see if there is a connection.. Thanks bud
I'd be inclined to put a small filter on the end like an old style CCV.
get rid of them stacked blocks as well, find a one piece.
what exactly goes onthe end of the hose, and also what does the filter do. What is the difference in the stacked blocks and the one piece?.
Nothing goes on to the end of the hose, and if you don't submurge the thing then nothing needs to go on the end of the hose.
There really isn't anything wrong with short stacked blocks so long as the ubolts were torqued properly. |
Cool thanks I just wanted to make sure it wasn't some thing important.
