Exhaust manifold to up pipe torque specs - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-19-2011, 06:24 PM Thread Starter
KCPowerStroker's Avatar
Just did an egr delete/oil cooler replacement and need to know the torque specs for the new up pipe to the exhaust manifold bolts as well as driver side exhaust manifold to y pipe bolts.
Thanks
Eric
2016 F250 CCSB Platinum
6.7L Powerstroke
Black
KCPowerStroker is offline
post #2 of 5 Old 11-19-2011, 06:35 PM
information regurgitator
NYC F-350's Avatar
Quoted: 54 Post(s)
exhaust manifold to y-pipe, 30ft/lbs or 40Nm
Just be sure the turbo to y-pipe connection is perfect before tightening anything up.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 5 Old 11-19-2011, 06:47 PM
I just did my delete also.
Just make sure everything is lined up first that is the most important thing. I didnt follow any torque specs but just tighten them and dont break them.
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
post #4 of 5 Old 11-19-2011, 06:49 PM
NYC F-350's Avatar
Quoted: 54 Post(s)
I never even thought of looking for torque specs for exhaust. I did the same as you, tight but not over tight. Tight enough to make sure there isn't an exhaust leak, and DO NOT leave the metal gasket out of the y-pipe to up-pipe connection on the passenger side......
Please
post #5 of 5 Old 11-20-2011, 07:02 AM Thread Starter
Thanks for the replys, just worried about leaks so wanted to be sure I got them tight enough.
Everything lined up well and gasket is between up pipe and y pipe.
Thanks again,
Eric
6.7L Powerstroke
Black
