ATF added to fuel? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 11-18-2011, 10:06 AM Thread Starter
Chapter Director
psd_va's Avatar
ATF added to fuel?
hey quick question i every so often add a quart of atf to my tank to help with lubrication of fuel system such as injectors and also for cleaning purposes. well my question is dose it matter what kind of ATF i add to the tank? i normally just got some off brand cheap stuff from gas station. well i have some honda ATF-Z1 fluid and also have some GM ATF6.
can i add either of these or any ATF for that matter and get the same benifits with out any issue?
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #2 of 27 Old 11-18-2011, 10:12 AM
Deathrod's Avatar
Quoted: 3 Post(s)
stick with 2 stroke oil....cheaper from wal mart anyway. some say yes for atf, some strongly against it
Deathrod is offline
post #3 of 27 Old 11-18-2011, 10:43 AM Thread Starter
Chapter Director
psd_va's Avatar
i was using ATF cause i get it for free basically. dose it matter what kind of 2 stroke oil and how much and how often
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 27 Old 11-18-2011, 10:47 AM
Daxman's Avatar
Just curious, what are the benefits of running ATF or 2 stroke oil in the fuel tank. Can i hurt or damage the engine or will it make it smoke like hell until it burns out. I've heard alot of people do this, i mean does it do that much good? Im sorry for all the questions.
Daxman is offline
post #5 of 27 Old 11-18-2011, 10:52 AM
Deathrod's Avatar
Quoted: 3 Post(s)
I run a quart of the wal mart brand with every tank (30 gal). I lubes the fuel system, mainly the fuel side of the injectors. Search on here or google...probably a million threads on the topic
Deathrod is offline
post #6 of 27 Old 11-18-2011, 11:33 AM Thread Starter
Chapter Director
psd_va's Avatar
ok thanks ill check it out
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #7 of 27 Old 11-18-2011, 12:20 PM
RckHrdRideFree's Avatar
I have seen this done quite frequently in Iraq. We were replacing fuel injection pumps left and right in the beginning until we got a tip to tell the operators to add 1Qt of ATF at every fill up. Made a major reduction in the number of injection pump replacements afterwards. Not sure how or if it would affect our engines but it did not cause our engines to smoke nor did I see any ill effects from it.
2006 F250 6.0 Harley Davidson Edition Completely Stock
RckHrdRideFree is offline
post #8 of 27 Old 11-18-2011, 12:53 PM
sbarbee54's Avatar
heck just by some opti-lube XPD in the gallonw size and add it every fill up. it is around 100 bucks and treats something like 400 gallons.
2005 F-250 CC SB FX4 Lariat 6.0
SCT Live Wire Tunes By Quick Tricks
MRBP 5" Straight Pipe
Banks Intake
GlowShift 4 Pillar/4 Mirror Pod
Kenwood DNX8120/Diamond Audio System
10" Sky Jacker Lift W/Procomp Rezies
Amp Steps/TopGun Customz Dual Fox Stear
Yukon 4:56's
Zoodad Mod/6.4 Banjo Bolts/Blue Spring Mod
PMF Trackbar/Draglink
20" Helo Maxx 8's W/ Toto MT 38X15.50R20's
sbarbee54 is offline
post #9 of 27 Old 11-18-2011, 01:04 PM
mustangman02232's Avatar
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
I use ATF 2 stroke or power service. I would also recommend buying a bottle of marvels mystery oil to put in and keep the bottle. It's basically ATF but says on the bottle "for use in ultra low sulfer diesel" so that way if you get your tank dipped you have some sort of wAy to fight (red fuel =offload)
2009 F350 CCSB Lariat 5.4
fisher MM2, 20% tint, leveled
2003 mustang cobra vert
SLP LM1, CAI, diablow tuner
2004 F350 reg cab 4x4 6.0 (SOLD)
exhaust/tune/deleted, dieselsite coolant filter, CAT ELC, blue spring, fisher MM2,
13.9 @95 mph
2002 Mustang 3.8 auto vert boltons (SOLD)
90 F350 RCLB IDI (SOLD)
mustangman02232 is offline
post #10 of 27 Old 11-18-2011, 02:09 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
Personally, I wouldn't run ATF as it has friction modifiers and is designed to provide a specific level of lubrication without allowing for slippage. That, and it isn't designed to be burned. 2 Stroke oil on the other hand is designed to be burned, and is ashless. It's sole purpose is to ensure that the moving parts in a 2 stroke stay lubricated. Just get some ASHLESS 2 stroke oil, and run it! It's cheaper, and IMO, better than ATF.
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
