Shopping F-diesels....Should I be scared of the 6.0? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-18-2011, 05:49 AM Thread Starter
I'm shopping F-diesels. I like the styling more of the 08+ 6.4 but I see a lot more 6.0s out there on the market, some at good prices. Should I be as scared of the 6.0 as I am feeling? I know the mods to do, but what should I look at from the seller? Is one with 100k+ mileage something to consider or no. For instance 06 King Ranch 6.0 131k miles listed at $18k.
Talk me into a 6.0.
mattmcphail is offline
post #2 of 15 Old 11-18-2011, 06:11 AM
PerformanceMachineMFG's Avatar
Talk me into a 6.0.
Depends if you are wanting to spend the money it takes to make these things reliable. Depending on what the condition of everything really dictates the amount of money you're going to be spending. If you are looking to make that investment then the 6.0's are wonderful trucks.
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
PerformanceMachineMFG is offline
post #3 of 15 Old 11-18-2011, 06:17 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 27 Post(s)
Feedback Score: 4 reviews
I wouldn't take a newer truck unless it was given to me, and I still got to keep my 6.0 . I love my 6.0. If you hang around here enough, you'll find that most every 6.0 problem has a fix, with aftermarket parts. That truck you mentioned looks like a good price, and I wouldn't be shy of mileage like that. There are 6.0's out there with over 500k on the original engine
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #4 of 15 Old 11-18-2011, 06:27 AM
Galaxie's Avatar
Making the 6.0 not die is easy. Clean coolant really at the end of the day. But there are a few other things that go into it as well.
Dig around you will see!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 15 Old 11-18-2011, 06:30 AM Thread Starter
What is an appropriate budget for the necessary mods? assuming it includes tuned, egr delete, coolant flinch.and change etc.
post #6 of 15 Old 11-18-2011, 07:09 AM
EGR delete $350, BPD oil cooler $1900 (the two main things to do), blue spring FPR kit $50, 6.4 banjo bolts $15, ICP $150, Turbo cleaning $free (if you have the time and a dremel tool), 5W-40 full synthetic $165, rev-x $79, Edge Insight CTS $350, SCT SF3 $350, Custom tunes $80 a piece. Having a 9000 lb truck that will run a 1/4 mile in 13.6 sec, priceless.
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #7 of 15 Old 11-18-2011, 07:27 AM
Wouldn't the BPD oil cooler be optional if he did a flush with Cat EC-1 coolant and did the delete/upgraded EGR and stock oil cooler?
pl77 is offline
post #8 of 15 Old 11-18-2011, 07:43 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yes it would be. If you can do your own work you can pretty much bulletproof your truck for around $1000. Dicad erg delete $150, Tousley oil cooler $220, STC upgrade fitting $65, flush and coolant change $200, coolant filter $140, Throw in a bypass oil filter for $250 and you should have a really solid truck. If the FICM goes out it can be repaired for for a couple hundred ore you can get a 58v upgrade with PHP custom tuning for about $500.
I'll take a 6.0 over the 6.4 or 6.7 any day.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 15 Old 11-18-2011, 07:48 AM
IMO the Cat EC-1 and a new stock oil cooler and upgraded EGR is just prolonging the problem until the oil cooler ruptures. The stock oil cooler is VERY VERY poorly designed. If you do that you still have to be paranoid and monitor your EOT-ECT delta just waiting for something to happen. That doesn't even mention that CAT EC-1 costs about $35/gal and you still have to buy a coolant filter, and flush every 50000 miles with it. If you have the cash do the BPD oil cooler, forget about EOT-ECT diff, put whatever coolant you want in it, flush once a year with $9/gal coolant and be happy as hell.
That's IMO though, to each his own.
post #10 of 15 Old 11-18-2011, 08:01 AM
Quoted: 26 Post(s)
I like the styling more of the 08+ 6.4...
WOW really?! I absolutely HATE the 08-10 trucks. The 11's still make me cringe a little. Maybe they will grow on me one day. The 05-07 is by far my favorite with the 92-97 OBS trucks then MAYBE the 99-04.
The 6.4 trucks have there own share of problems that I would say are sometimes worse than the 6.0. For the 6.0 for sure. If you get dual climate control in a 6.4 you can gaurantee you'll be replacing at least one blend door actuator motor and one of them requires removing the entire dash and evaporator box. There is also the rash of coolant leaks that the 6.4 is plagued with. My good buddy had a MINT job 3 '08 and his had a mix of both of those problems. Guess what he drives now? An '06 6.0 king ranch with 210k miles.
Banshee365 is offline
