STC Fitting Repair ?s - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-17-2011, 08:08 AM Thread Starter
Stroked7.3's Avatar
Send a message via AIM to Stroked7.3
Csn someone tell me what else I need when I do the STC Repair? Im going to get the parts tomorrow and need to know what else I need. Do I need a turbo mount kit or use the old stuff? I have all the tools just need to know what other parts to get.
GHOST RIDER
2006 F350 CCSB
Bully Dog PMT-Gauges Only, AirRaid Intake, 4" Straight Piped w/ 8" Tip
8" Lift, Bilstein 7100s, Dual Stabilizers, 37x13.50 Toyo MTs on 22" XD Black Monsters
08 Tailgate, Upfitter Switch Hi-Idle Mod, High Beam Fog Mod, 6K HID Heads and Fogs, 5% Tint
Pioneer Z2/Z3, Kicker Components, JL JX 360/4, (2) JL 12s, JL JX 1000/1
Soon to come:
SCT w/TDS and SRL Tune
EGR Delete
Custom Traction Bars
Stroked7.3 is offline
post #2 of 7 Old 11-17-2011, 08:24 AM
dleopard19's Avatar
hpop cover gasket, turbo drain tube o-rings, oil feel line gasket to turbo, and it should come with the two o-rings to reseal the hpop to the block (its a yellow o-ring) and where the stc fitting lies theres a black o-ring but that should be all you need, inspect the ipr valve while your in there and id probably go ahead and get ipr rebuild kit, has new orings and a new screen its easy to do and it not expensive at all
04 PSD SCT X3 extreme race tuned by innovative and looney tuned, straight pipe and dumped before rear tire, afe intake, smoke switch, air dogged out, zoodad mod, egr delete kit (finally), head studs, cfm intake elbow, bd boost fooler, installed new cab lights (didnt have em from factory) 285 bfg mt's, suncoast tq converter, she'll run a 13.4...soon to come a baby lol my mods stop here for now
dleopard19 is offline
post #3 of 7 Old 11-17-2011, 09:55 AM
sbarbee54's Avatar
question, is this something I can also do when I am cleaning my turbo? Because I have the upgraded drain tube supply line and turbo mounting kit. I just figured while I am in there is there anything else right there I should do.
2005 F-250 CC SB FX4 Lariat 6.0
SCT Live Wire Tunes By Quick Tricks
MRBP 5" Straight Pipe
Banks Intake
GlowShift 4 Pillar/4 Mirror Pod
Kenwood DNX8120/Diamond Audio System
10" Sky Jacker Lift W/Procomp Rezies
Amp Steps/TopGun Customz Dual Fox Stear
Yukon 4:56's
Zoodad Mod/6.4 Banjo Bolts/Blue Spring Mod
PMF Trackbar/Draglink
20" Helo Maxx 8's W/ Toto MT 38X15.50R20's
sbarbee54 is offline
post #4 of 7 Old 11-17-2011, 11:59 AM
Here is the link to my post when I did this job. GOOD LUCK
No longer a 6.0 virgin. New STC, Cleaned turbo, welded EGR cooler closed. PIC's
HAM_RADIO_MAN is offline
post #5 of 7 Old 11-17-2011, 12:09 PM
You will need to rent, buy or make a 15/16 crows foot to properly torque the new fitting. A 1 3/8 wrench is handy to get the IPR out. You will be getting a lot of air into the HP oil system so don't freak out if it takes a LOT of cranking to get it started ofter you are done. Some have also reported the truck running like crap for the first 1/4 tank of fuel untill all the air is worked out of the HP oil system.
post #6 of 7 Old 11-17-2011, 07:12 PM Thread Starter
Stroked7.3's Avatar
Thanks for the help guys I feel confident enough to do it, Ive been watching videos and reading up on it for awhile.
GHOST RIDER
2006 F350 CCSB
Soon to come:
EGR Delete
post #7 of 7 Old 11-17-2011, 07:35 PM Thread Starter
Stroked7.3's Avatar
Also does anyone know if the gaskets and orings i need cross reference to any International part #s as ill be there tomorrow.
GHOST RIDER
2006 F350 CCSB
Soon to come:
EGR Delete
