Why am I suddenly blowing the same fuse over and over? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-15-2011, 06:49 PM Thread Starter
My '06 has decided to keep blowing the same fuse. It is no. 17, controls the dash lights, door switch lights, and taillights. The headlights, turn and brake lights work.
It happened last week, tracked down the fuse, changed it and driving less than 5 min, blew again.
Any thoughts?
Oh, it also controls the foglights.
'06, XLT, F350 FX4, Auto, Ext. Cab Short bed
Diamond Eye Turbo-back 4" exhaust.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
beemerbiker5 is offline
post #2 of 14 Old 11-16-2011, 04:35 AM
Term3's Avatar
If you keep blowing fuses I would check for a short. Somewhere a wire is making contact with ground. Good luck as these can be a real pain to find. I wouldn't ignore it and put in a bigger fuse. I know a guy that did that and his truck caught fire.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 14 Old 11-16-2011, 04:51 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
You've got a short somewhere. Any recent electrical changes to that circuit?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 14 Old 11-16-2011, 06:07 AM Thread Starter
No, just happened out of the blue. Have not done any work to any of the electrical systems.
That is what is odd. I know there is a short someplace, but not sure how or where it has occured. Until now, had zero electrical issues.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #5 of 14 Old 11-16-2011, 08:12 AM
soccerman's Avatar
Has it been raining where you are? I had a problem with my last f350 that when it rained, it leaked into the tail light and short the system there. I had a crack in the tail light assembly that I didn't think much of until it cause me problems.
*Check all your lights for cracks of any size and either fix them or replace them.
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #6 of 14 Old 11-16-2011, 08:15 AM
Term3's Avatar
Most of the wiring bundles are on the drivers side so the only thing I can suggest is to start at the front push and move from side to side on bundles every foot or so while a friend watches for the fuse to blow because a wire is touching metal somewhere.
Term3 is offline
post #7 of 14 Old 11-16-2011, 09:33 AM Thread Starter
No rain. Just blown fuse. I will have to start a hunting expedition, I suppose.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #8 of 14 Old 11-16-2011, 10:26 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I expect the harness chafed somewhere and you are getting a ground fault.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 14 Old 11-16-2011, 01:39 PM Thread Starter
Is there a spot where this is most likely the culprit? Or several spots? I don't want to check the entire harness if there is a/several problem spots I can start at.
thanks
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #10 of 14 Old 11-16-2011, 01:52 PM
Term3's Avatar
Check locations that pass over an edge such as the frame and locations that do not have that corrugated plastic covering on the taped bundle. Also check locations that would get a lot of heat, for example the bundles that come down the firewall near the exhaust manifold gets a lot of radiant heat and that protective corrugated plastic cover breaks down and gets brittle.
Term3 is offline
