Help! Possible bad Hub - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-14-2011, 08:02 PM Thread Starter
mtpolarbear's Avatar
I just redid my front end COMPLETELY. New ball joints, tie rods, new axle u-joints, new tires, new energy suspension master bushing kit. The problem is I didnot check the 4x4 after I did all the work(a month ago when it was still warm). Now its snowing and cold tonight and when I drove te truck and engaged the four wheel drive I hear a clunking sound in the drivers front wheel.. Take it out of four wheel and it goes away. Did I miss something when I put it back together. I did put new seals in and greased the bearings. Help!
POLARBEAR - 2003 F-250 SD CC SB FX4, 6.0, 3:73 gears, EGR & Cooler Delete, Bulletproof Oil Cooler, ARP Studs, A.R.E. Topper, Bedrug, Zoodad, 5" Magnaflow turbo back, K & N cold air intake, coolant filter, EDGE INSIGHT CTS, SCT X3 Tuned by Vivian, Energy Suspension Master Bushing kit, RiffRaff Boots, Blue Spring, 6.4 Banjo's, Fumoto Oil Valve, Fumoto water drain plug, Whistler 2000 Watt Inverter, DC Power 200amp Alt. Rebuilt FICM w/Atlas 40, Riff Raff Boots and counting.
mtpolarbear is offline
post #2 of 3 Old 11-15-2011, 07:45 AM
Jayson41's Avatar
did you try locking the hub yourself and seeing if the noise went away?
Bullet Proof Diesel Semi Bullet Proof Kit - Diesel Site Coolant Filter - Banks Monster 4" Exhaust - High Idel Switch - 2.5 inch Leveling Kit - 295/70/18 Nitto Trail Grappler M/T's - Amsoil
Jayson41 is offline
post #3 of 3 Old 11-15-2011, 08:00 AM Thread Starter
I am getting ready to go out and work on it. That is teh first thing to do. If it goes away with the hub locked, then what?
