REALLY REALLY NEED HELP !!! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-14-2011, 03:28 PM Thread Starter
Unhappy REALLY REALLY NEED HELP !!!
well i bought my first diesel about a week ago (03 f350 4X4 6.0l w/84,000 miles) when pulling my horse trailer on about a 40 mile round trip with some bad hills, i noticed after i got home the truck had spitt up some coolant but not alot only about 1 1/2 quarts ,so i took it to a ford dealership today and they said blown head gaskets as soon as i mentioned spitting coolant.they also never even came to look at it ,so i just decided to get a second opinion .the truck has no white smoke and runs great with no misses and no water in oil and tail pipe is dry ...could this still be head gaskets ????or what else could it be ???? any help will be greatly appriceated thanks... just let me know if theres anything else u need to know
ck94 is offline
post #2 of 15 Old 11-14-2011, 03:39 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
First things first.
A: Try a new degas bottle cap
B: You should have the coolant level no higher than the "add" line when hot
C: Park the truck on a good hill, nose down. Pull the egr valve out or the intake. Leave it like this overnight. In the morning, check the bottom of the hole for the presence of moisture. If you see moisture, your EGR cooler has failed, which was caused by a plugged oil cooler. BOTH of them would have to be replaced (or delete your egr cooler).
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 15 Old 11-14-2011, 03:52 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Also want to add, with the '03 the original Degas bottle. The min line is the new max line.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 15 Old 11-14-2011, 04:28 PM Thread Starter
After I turn the truck off after a drive and raise the hood I I can hear a whistle noise coming from the degas bottle cap....is this normal or could this be a bad cap?
ck94 is offline
post #5 of 15 Old 11-14-2011, 04:36 PM
2003kingranch's Avatar
sounds like a bad cap
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #6 of 15 Old 11-14-2011, 05:23 PM Thread Starter
Will it hurt to drive it??? And us there any way to know if it is a bad cap?
ck94 is offline
post #7 of 15 Old 11-14-2011, 05:26 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Just go buy a new updated cap from Ford. It's like $10, and they should have them in stock.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #8 of 15 Old 11-14-2011, 05:35 PM Thread Starter
But will it hurt it to drive it if it was something else??
ck94 is offline
post #9 of 15 Old 11-14-2011, 05:38 PM
does your cap look like this?
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #10 of 15 Old 11-14-2011, 05:50 PM
Powerstroke Techie
forddieseldoctor's Avatar
If it is head gaskets and you keep driving it the coolant level will continue to fall. If it gets low enough before you catch it you will damage your egr cooler. If it's whistling and puking then there is a good possibility of a head gasket being failed. But once you put the new cap on take the truck out warm it up, pull over and relieve the pressure from the cooling system, tighten the cap back up, then accelerate safely at wot to 60 mph from as close to a dead stop as you can. Repeat this one or two more times, then pull over and see if your upper radiator hose is hard again. If it's hard repeat the entire procedure again. If your upper hose gets hard again then more than likely you have a headgasket leak. However I have seen a bad egr cooler show up as a bad headgasket. But yours is an 03 so I very highly doubt that your cooler is failed as I've only seen one of that style cooler fail. But before you tear it apart to replace head gaskets you should find a way to monitor your coolant temp and oil temp and make sure that once your coolant reaches 190*F your oil temp doesn't get more than 15* above that during a road test. Or just plan on replacing your oil cooler. And if you have to open your motor up I highly recommend flushing your cooling system with motorcraft vc-9.
If you want the flushing directions pm me your email and I'll send you a copy.
I hope I didn't make this too confusing for you. Just holler if you need anymore help.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
