FICM Cal # or FICM strategy# - Ford Powerstroke Diesel Forum
Old 11-14-2011, 08:24 AM
How can i retreve the FICM #??
and how can it be changed?? can i change it through who ever i get custom tunes??
Old 11-14-2011, 08:36 AM
information regurgitator
You would need a tuner that is capable of "reading" the strategy programming number such as an SCT. Basically, there are two 'strategies.' The ECM and FICM. You can change both by contacting Power Hungry Performance.
Power Hungry Performance - FICM Reprogramming
Your custom tune writer will need to know what strategy you have to write the tunes for you.
Old 11-14-2011, 09:26 AM
so i do have a SCT and checked my strategy # is the letters,#'s, below it the #'s for the FCIM?
Old 11-14-2011, 09:29 AM
Post up what you found. There should be three sets of numbers/letters
Old 11-14-2011, 10:06 AM
VXCF4H2
TQCJ0H3
Old 11-14-2011, 10:29 AM
Originally Posted by Milehighturbo View Post
VXCF4H2
TQCJ0H3
The VXCF4H2 is the ECM strategy
I am not completely sure about the TQCJ0H3, but I think that is the FICM.
Old 11-14-2011, 10:32 AM
285,261,190
VXCF4H2
TQCJ0H3
VXCF4H2 is you ecm
TQCJ0H3 is your Trans
Old 11-14-2011, 10:33 AM
Thank you for clearing that up, mudrunninpig. I'm still learning this whole "strategy" stuff.
The VXCF4 strategies seem to be the preferred strategies. You probably will not need to do a "rollback" on that, though PHP can install a flash tune on top of it and disable the egr commands. They can also install a FICM tune. If your end result is that you just want to get rid of a code generated by an egr cooler delete, the ECM flash to disable the egr functions might be the way to go (cheaper than a tuner/custom tune).
Old 11-14-2011, 11:12 AM
Originally Posted by mudrunninpig View Post
VXCF4H2 is you ecm
That makes sense my buddys # are
VXCF4CB
TQCJ03C
AMEZ2AL12-----I BELEAVE THIS IS THE FICM #
but how do i retreave this #?
