Cracked Radiator - Ford Powerstroke Diesel Forum
Old 11-14-2011, 05:48 AM
Question Cracked Radiator
My '06 F250 Super Duty 6.0L blew out the radiator about two miles into a pretty good grade. The top plastic tank actually cracked, and I'm wondering if this is a normal case of failure or could the cause be too much pressure in the cooling system do to something else, like the turbo or ? The motor didn't get hot but made a mess all over the windshield. I patched the radiator with J-Weld covered the water tank with duct tape to avoid pressure build up and eased it home with no issues, again didn't get hot.
Old 11-14-2011, 06:16 AM
Feedback Score: 7 reviews
I doubt it was caused by too much pressure, the cap will bleed off excess pressure over 16 psi.
I've not heard about that many failed radiators (read about some but not that often).
Even with all the guys (including myself) that have had blown head gaskets that over pressures the cooling system, I don't think I've heard of any that also blew the radiator because of it.
BPD (Bullet Proof Diesel) sells an all aluminum replacement radiator as well as Mishimoto
Old 11-14-2011, 06:57 AM
Cracked Radiator
It was odd, one second I'm fine the next I have water spewing from the top tank like you can't believe? Maybe the cap failed, who knows. I'll try the replacing the radiator and go from there.
Okay, thanks for the help and I will look into the all-aluminum version for my truck.
Old 11-14-2011, 08:07 AM
THese are the places that I know of.
Performance Radiator for 2003-2007 6.0L Ford Powerstroke
Ford F250 w/ 6.0L Powerstroke Engine Aluminum Radiator, 2003-2007, by Mishimoto
All-Aluminum Radiator Ford Power Stroke Diesel 6.0
Old 11-14-2011, 08:41 AM
Thanks for the help!!
