HELP!! wheel studs keep breaking - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-13-2011, 02:09 PM Thread Starter
brad189's Avatar
Like the title says wheel studs keep breaking.. This all started after i lifted my truck. I figured the first time it happened was bc the lug nuts i was sold didnt tighten down all the way bc they were closed end and the stud bottomed out. my hub also went out right before this and i kept driving it for a little bit.. could that have also caused it? Now i replaced the hub with a used one from a junk yard and put on 2in wheel spacers on all 4 tires and everything has been fine for about 3-4 months... then friday night i was driving home and broke 7 wheel studs on the same side as before.. passenger side front. but this time it was the wheel spacer studs.. i think the lug nuts came loose, but im not sure..
So i need help?!?!?!?!?!?!?!?!?!
-brad
brad189 is offline
post #2 of 18 Old 11-13-2011, 03:12 PM
back in the saddle
shu873's Avatar
The spacers are your problem. Are you torquing them correctly when you install them? Even if torqued properly I'm not a big fan of them. They are the weak link causing you to break studs.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 18 Old 11-13-2011, 03:17 PM
Quoted: 4 Post(s)
Are you running hub centric wheels and spacers?
Jason
JasonY is offline
post #4 of 18 Old 11-13-2011, 03:17 PM Thread Starter
brad189's Avatar
Well the first time it was the factory studs broke. So I replaced the hub and bought wheel spacers. Then the wheel studs on the spacer broke. Both times was the same wheel. I know the spacers aren't that strong but I don't off road or town anything. There has to be an under laying issue
brad189 is offline
post #5 of 18 Old 11-13-2011, 03:18 PM Thread Starter
brad189's Avatar
To be honest idk if they are hub centric or lug centric
brad189 is offline
post #6 of 18 Old 11-13-2011, 03:30 PM
Quoted: 4 Post(s)
That's where id start, hubcentric or bust on a rig this heavy.
Jason
JasonY is offline
post #7 of 18 Old 11-13-2011, 03:33 PM Thread Starter
brad189's Avatar
how do i figure out if they are hub centric or lug centric?
brad189 is offline
post #8 of 18 Old 11-13-2011, 04:47 PM
2 INCH WHEEL SPACERS! HOLY SHEET BATMAN! The wheel hub is a tight fit on the hub of the truck and sets it in place and gets mounted. You add 2'' of aluminum hanging off all your studs are taking the abuse.
Turbo cleaning
HG In Cab:
Leaky Oil Pan Bedplate:
FICM testing
If you think the 6.0 is bad.....Get a 6.4
Rotbody is offline
post #9 of 18 Old 11-13-2011, 04:51 PM Thread Starter
brad189's Avatar
ok well my wheels are hub centric...so are the spacers.. my buddy has 2in spacers on his f250 that he towns 10,000 + lbs daily with out a problem and another one of my buddies had an f250 with spacers and never had a problem.. it just seems like ive had nothing but problems with my passenger side front end since i lifted it.. before i had spacers i had the same problem... possibly something wrong with my front end???
brad189 is offline
post #10 of 18 Old 11-13-2011, 06:49 PM
SandawgK5's Avatar
Garage
What are you torqueing them to? I would say you either over torqued and yeilded the studs or under torqued and they loosened and broke them. All the studs I have seen fail generally came down to an issue with how they were tightened.
Dik
SandawgK5 is offline
