Tea Kettle Whistle? Only when letting off the gas? - Ford Powerstroke Diesel Forum
Old 11-12-2011, 08:30 AM
I noticed just recently I have been getting the tea kettle whistle, but only when letting off the gas and for short periods of time. From what I have read, is it most likely a bad degas bottle cap. I have noticed very small amounts of coolant leaking out the cap. It is certainly not " puking " a lot of coolant, just a few drops here and there. Do you all think it is a bad cap? no other symptoms of anything else and I have a 2006 f-250
Old 11-12-2011, 10:10 AM
You could start with a new cap but you had better get some gauges sounds like EGR cooler or HGs the new full cold mark is the add mark. You have to know the spread on ECT-EOT max 15* but i think if you are close to 10* doing 60mph after 5-10min on flat ground you have a problem. Something like the http://www.scangauge.com/ or the Edge Insight CTS work well and are great tools.
2 stroker
Old 11-12-2011, 12:04 PM
So I got the new cap and put it on, haven't had chance to drive yet, but will report back if it clears everything up. I'm really freaking out about this. I don't have extra money right now for big repairs. I just bought the truck used about 2 months ago. 2006 f-250 KR CCLB w/ 113,000 miles on it. Oasis report showed it had new oil cooler and EGR cooler installed about 30000 miles ago under warranty. I have had no white smoke or other symptoms of blown HG's. Truck has been running perfectly aside from this whistle.
I was planning on buying an edge insight CTS anyway, just wasn't planning on this soon. Like I said, I have no extra money at the moment. I guess I'll have to work something out to at least get the CTS to check my temps. This could be my worst nightmare!!!!
Old 11-12-2011, 12:06 PM
Also, maybe I have too much coolant in degas bottle. I don't have the sticker on my degas bottle denoting the different min max and when engine is cold, the coolant is filled to the max label on the bottle
Old 11-12-2011, 12:11 PM
Yes the Edge Insight is a great tool you will know where you stand when it comes to the temps get it sooner than later. Hope it all works out for you.
2 stroker
Old 11-12-2011, 12:29 PM
I would like to know the outcome of the new cap. I am not having the yea kettle sound, but as you described, I am having a few drops here and there leaking out of degas bottle through cap. No other symptoms, and my CTS shows my temps to be well within the range.
2006 F250 Lariat FX4:
MBRP 4" Turbo Back Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle Mod
Dieselsite Coolant Filter
58v Swamps FICM
SCT w/ Matt's SRL Tune
Old 11-12-2011, 01:09 PM
The coolant must be at the add mark when COLD this is the new full mark Ford has a new sticked to install on the oil degasing tank i'm told i just use the ADD mark.
2 stroker
Old 11-12-2011, 01:30 PM
well if I'm at the max mark when cold could this be why I am getting some coolant coming out of the bottle? Maybe it has too much coolant in it
Old 11-12-2011, 02:53 PM
information regurgitator
Yep, it could be as simple as that.
I actually run the coolant a little lower than that, I run it at the add mark when HOT.
Old 11-12-2011, 02:56 PM
Mine used to do that. EGR was shot. Could be something else in your case but its prob the cap, egr cooler, or headgaskets, or a combo.
