Where can I get cab step bolts for OEM cab steps? Picture inside - Ford Powerstroke Diesel Forum
Old 11-11-2011, 04:41 PM
I took my cab steps off a while ago but now i want to put them back on. I lost all the bolts that i removed to take them off. You can see the side steps im talking about, heres my truck when i had them on. Where can i get the oem bolts to put them back on?
Old 11-11-2011, 04:50 PM
If the little clips are still up under there attached to the body then pop one out and take it to the hardware store and get some metric bolts for it. If I recall those bolts were about 1"-1.5" long. This might be the quickest and easiest way to get some.
Old 11-11-2011, 05:05 PM
there still on the body, and thanks thats probably what ill do
Old 11-12-2011, 03:58 AM
NOT a Democrat
I have a set of stock hardware some place.... I will look for you to see if I have it.
At the moment, I am building a Galaxie, fixing my house, putting in a Buck Stove. The chances of them all being in one spot are the same chances of it raining hot women from the sky. I will try to look today cheif!
