This mean bad Egr Cooler? Pics
Few days ago truck started running terrible under load smoking everything, thing I found problem does this look like egr cooler fail, kinda smells of coolant too.
Certainly looks like it to me.
Uhm, I can tell you if mine looked like that the EGR cooler would be getting replaced. It is suppose to be dry like a black chaulk .
Really appreciate quick response looks like it's getting deleted
The plugging of the oil cooler coolant passages slows the coolant flow to the egr cooler. The slower moving coolant allows the egr cooler to overheat. The overheating gets worse as the oil cooler becomes more plugged up. Eventually the overheating causes the egr cooler to fail. Deleting the egr cooler without addressing the oil cooler could result in the oil cooler exploding internally. Replace the oil cooler AND delete the egr cooler. |
I was planning on it since I would be there, is there anything I need other then the delete kit and new oil cooler?
arp studs too
hahahaha
If you delete the EGR cooler, rebuild or replace your oil cooler, and clean your cooling system you should be good! Studs if you plan on bigger injector and or turbo. If you are running those stock and just tuning, no studs needed most likely!
For a real eye opener, park nose down over night and see what you get in the EGR valve hole.
Should it be alright to replace everything, then flush or opposite before replacing oil cooler.
