Coolant bypass install ?
Just got my sisniter coolant bypass delivered and just wondering how much coolant I will lose during the install.The dealer just did a coolant flush with the gold,I know I know but I figured it has been flushed and I wanted to to get the bypass on there.Do I need to get more coolant for the install?....thx
Some say they lose very little coolant on install. Myself, I drained some off into a clean container and re-used. You will need to fill to correct line to make up for the filter.
I used a tubing cutter, probably lost a pint at the most. Just have a plan and be quick putting it back together.
Thx everybody..I will pick up some coolant I guess before I do this..Just in case...
I was loosing a good amount before I could switch hands and grab the clamp.
clamp your hoses. |
Do I really have to mix distilled water in even If I only lose about a 1/2 gallon or so?
Tap water, with minerals and crap is no good for the cooling system. For $1 get distilled.
get distilled.
What I mean is can I just pour in some gold straight up or do I have to mix it with distilled,,,,thx
